Float/Curve patch
Float/Curve patch Mark Probst 22 May 23:43
Float/Curve patch Øyvind Kolås 23 May 00:18
Mark Probst
2007-05-22 23:43:27 UTC (almost 18 years ago)
Float/Curve patch
Hi!
Here's a small patch that corrects the floating point I/O problem for the curve and makes the contrast-curve operation use the curve instead of the object param type.
Mark
Øyvind Kolås
2007-05-23 00:18:38 UTC (almost 18 years ago)
Float/Curve patch
Committed, one adjustment to how you create patches that would making commiting the patches easier is if you included an entry for the ChangeLog as well.
/Øyvind K.
