Layer modes: Add vivid light blend mode?
8 of 9 messages available
1151032079.12075657.1484667... 22 Jan 10:38
  Layer modes: Add vivid light blend mode? Jan Buchmann via gimp-developer-list 17 Jan 15:46
   Layer modes: Add vivid light blend mode? Alexandre Prokoudine 22 Jan 12:29
    Layer modes: Add vivid light blend mode? Alexandre Prokoudine 22 Jan 14:19
     Layer modes: Add vivid light blend mode? Laxminarayan Kamath 23 Jan 11:58
      Layer modes: Add vivid light blend mode? Øyvind Kolås 23 Jan 12:36
       Layer modes: Add vivid light blend mode? Laxminarayan Kamath 23 Jan 13:05
      Layer modes: Add vivid light blend mode? Laxminarayan Kamath 23 Jan 12:58
      Layer modes: Add vivid light blend mode? Ell via gimp-developer-list 23 Jan 16:02
2017-01-17 15:46:03 UTC (over 8 years ago)
SORRY: Subject was missing in first mail
Dear all,
thanks for all the work being put in developing GIMP 2.10. The development will be a huge step for GIMP especially 16bit and color management. I'm using mostly the latest git version compiled via MacPorts on macOS.
I saw in GIT that you are working on the layer modes (linear vs gamma etc) currently. For some key adjustments that I do, I use the vivid light layer mode, which is only available via calling GMIC at the moment. Would it be hard to implement it also in core GIMP (GMIC seems to have an implementation)? I can't really judge the effort, but I think that would be great for other users as well that use this mode based on their history with PS and other tools.
Basic descriptions are here: https://en.wikipedia.org/wiki/Blend_modes (under dodge and burn)
Cheers, Jan
2017-01-22 12:29:10 UTC (about 8 years ago)
https://bugzilla.gnome.org/show_bug.cgi?id=775857
Thomas would have to update that patch given all recent changes, though.
Alex
2017-01-22 14:19:12 UTC (about 8 years ago)
And another update: pippin independently added vivid light and more blending ops to Git master:
https://git.gnome.org/browse/gimp/commit/?id=c9ad09df6195e6ed59f3ece17b055eaed5891e22
They haven't been exposed in UI yet. That's on TODO list.
Alex
Laxminarayan Kamath
2017-01-23 11:58:08 UTC (about 8 years ago)
Hi all!
While you guys are at it, I encourage you to try out this formula:
E = (2 * I ) - M
I call it the "Opposite" mode. I derived it from how the unsharp mask does the sharpening - first run a grain extract and then do a grain merge.
It is not useful in an awful lot of places. But when you want to de-convolute in a strange way, and you have the procedure or a plugin which does only the convolution, "Opposite" layer mode can help you get there quickly!
It also has the "opposite" effect on most color effects as well!.
Cheers!
Laxminarayan Kamath Ammembal
http://lankerisms.blogspot.com
(+91) 9945036093
Øyvind Kolås
2017-01-23 12:36:12 UTC (about 8 years ago)
On Mon, Jan 23, 2017 at 12:58 PM, Laxminarayan Kamath wrote:
Hi all!
E = (2 * I ) - M
This is similar to something else I have experimented with, permitting opacity values below 0% and above 100% for normal mode, this permits implementing unsharp mask with a blur layer - as well as increasing saturation by blending a color image with it's desaturated variant.
/pippin
Laxminarayan Kamath
2017-01-23 12:58:29 UTC (about 8 years ago)
On second reading, the previous description is not that clear on how to use it. (unless you have read the unsharp mask script)
You have an image with a slight radial or zoom blur or motion blur (the photographer tried to be creative) . You duplicate the layer.
You measure and run the same exact blur again on the duplicated layer! Say the radial blur is about 10 degrees. You run the radial blur at 10 degrees. In the same direction as the original!
Then you switch the layer mode to "Opposite". Voila! if you measured right, the zoom/motion blur is reduced significantly!
For color effects it works as well, like for "add punch" from FxFoundary color effects,it removes the punch, etc.
For other kinds of effects, it gives various interesting results - for edge detect - instant painting/cartoon like effect :)
Laxminarayan Kamath
2017-01-23 13:05:14 UTC (about 8 years ago)
/pippin
Nice! looking forward to it :)
(+91) 9945036093
2017-01-23 16:02:41 UTC (about 8 years ago)
On 01/23/2017 06:58 AM, Laxminarayan Kamath wrote:
Hi all!
E = (2 * I ) - M
Note that the recent work in master removed the channel-value clamping that used to happen during blending (yay! :), and since each layer appears only once in this formula, you can implement this mode using the existing ones, with the help of some ancillary layers, but without having to duplicate the "content" layers (I and M).
-- Ell
