libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions
1 of 2 messages available
cBduxjYmILmBisRG1VIvmD@wSEe... 12 Jan 21:14
  libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions Michael Natterer 12 Jan 21:13
Michael Natterer
2017-01-12 21:13:56 UTC (over 8 years ago)
On Thu, 2017-01-12 at 21:57 +0100, Helmut Jarausch wrote:
On 01/12/2017 08:58:11 PM, Michael Natterer wrote:
It's only declared twice if GIMP_DISABLE_DEPRECATED is *not* defined. Can you paste the output of "make V=1" of gimpbase-private.c please?
Regards, Mitch
I've attached the log.
gimpbase-private.c  includes unconditionally
#include "config.h"
#include
#include "gimpbasetypes.h"
#include "gimpbase-private.h" #include "gimpcompatenums.h"
Here the first non-comment lines of gimpbasetypes.h
#ifndef __GIMP_BASE_TYPES_H__ #define __GIMP_BASE_TYPES_H__
#include #include
#include
#include
And here the first lines of gimpcompatenums.h
#ifndef __GIMP_COMPAT_ENUMS_H__ #define __GIMP_COMPAT_ENUMS_H__
G_BEGIN_DECLS
/*  These enums exist only for compatibility, their nicks are needed   *  for config file parsing; they are registered in gimp_base_init().
#define GIMP_TYPE_ADD_MASK_TYPE_COMPAT   (gimp_add_mask_type_compat_get_type ())
GType gimp_add_mask_type_compat_get_type (void) G_GNUC_CONST;
typedef enum {
   GIMP_ADD_WHITE_MASK          = GIMP_ADD_MASK_WHITE,    GIMP_ADD_BLACK_MASK          = GIMP_ADD_MASK_BLACK,    GIMP_ADD_ALPHA_MASK          = GIMP_ADD_MASK_ALPHA,    GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER,    GIMP_ADD_SELECTION_MASK      = GIMP_ADD_MASK_SELECTION,    GIMP_ADD_COPY_MASK           = GIMP_ADD_MASK_COPY,    GIMP_ADD_CHANNEL_MASK        = GIMP_ADD_MASK_CHANNEL } GimpAddMaskTypeCompat;
In bothes cases I don't see any conditional compilation which precludes
the double definitions.
In gimpbaseenums.h there clearly is #ifndef GIMP_DISABLE_DEPRECATED that protects GIMP_ADD_WHITE_MASK and the other compat values from being visible if it's defined.
In your build log there is -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE which are part of CPPFLAGS as assembled in configure.ac. A few lines above adding -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE it adds -DGIMP_DISABLE_DEPRECATED, also unconditionally.
You probably changed your configure.ac, I have no other explanation how -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE but NOT -DGIMP_DISABLE_DEPRECATED end up on your compiler command line.
Please have a look at your configure.ac:
CPPFLAGS="${CPPFLAGS} -DGIMP_DISABLE_DEPRECATED -DBABL_DISABLE_DEPRECATED -DGSEAL_ENABLE"
and a few lines below:
CPPFLAGS="${CPPFLAGS} -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE"
I have no explanation why the latter but not the former would make it to your compiler command line.
Please double check your source tree and maybe environment variables.
Regards, Mitch
