libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions
libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions Helmut Jarausch 12 Jan 17:14
  libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions Michael Natterer 12 Jan 18:01
   libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions Helmut Jarausch 12 Jan 19:16
    libgimpbase/gimpbaseenums.h and gimpcompatenums.h name collisions Michael Natterer 12 Jan 19:58
Helmut Jarausch
2017-01-12 17:14:30 UTC (over 8 years ago)
Hi, I cannot compile the GIT version (today 16:00 GMT) Both, gimpbaseenums.h and gimpcompatenums.h define several enums of the same name.
This is on Gentoo, gcc-6.3.0
Thanks for looking into it, Helmut.
Here are a few lines from the error log:
In file included from gimpbase-private.c:29:0: gimpcompatenums.h:36:3: error: redeclaration of enumerator 'GIMP_ADD_WHITE_MASK'
GIMP_ADD_WHITE_MASK = GIMP_ADD_MASK_WHITE, ^~~~~~~~~~~~~~~~~~~
In file included from gimpbasetypes.h:26:0, from gimpbase-private.c:26: ../libgimpbase/gimpbaseenums.h:52:3: note: previous definition of 'GIMP_ADD_WHITE_MASK' was here
GIMP_ADD_WHITE_MASK = GIMP_ADD_MASK_WHITE, /*< skip, pdb-skip >*/
In file included from gimpbase-private.c:29:0: gimpcompatenums.h:37:3: error: redeclaration of enumerator 'GIMP_ADD_BLACK_MASK'
GIMP_ADD_BLACK_MASK = GIMP_ADD_MASK_BLACK, ^~~~~~~~~~~~~~~~~~~
In file included from gimpbasetypes.h:26:0, from gimpbase-private.c:26: ../libgimpbase/gimpbaseenums.h:53:3: note: previous definition of 'GIMP_ADD_BLACK_MASK' was here
GIMP_ADD_BLACK_MASK = GIMP_ADD_MASK_BLACK, /*< skip, pdb-skip >*/
In file included from gimpbase-private.c:29:0: gimpcompatenums.h:38:3: error: redeclaration of enumerator 'GIMP_ADD_ALPHA_MASK'
GIMP_ADD_ALPHA_MASK = GIMP_ADD_MASK_ALPHA, ^~~~~~~~~~~~~~~~~~~
In file included from gimpbasetypes.h:26:0, from gimpbase-private.c:26: ../libgimpbase/gimpbaseenums.h:54:3: note: previous definition of 'GIMP_ADD_ALPHA_MASK' was here
GIMP_ADD_ALPHA_MASK = GIMP_ADD_MASK_ALPHA, /*< skip, pdb-skip >*/
In file included from gimpbase-private.c:29:0: gimpcompatenums.h:39:3: error: redeclaration of enumerator 'GIMP_ADD_ALPHA_TRANSFER_MASK'
GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~
In file included from gimpbasetypes.h:26:0, from gimpbase-private.c:26: ../libgimpbase/gimpbaseenums.h:55:3: note: previous definition of 'GIMP_ADD_ALPHA_TRANSFER_MASK' was here GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER, /*< skip, pdb-skip >*/
Michael Natterer
2017-01-12 18:01:14 UTC (over 8 years ago)
the same name.
This shouldn't happen, the resp. values in gimpbaseenums.h are protected by #ifndef GIMP_DISABLE_DEPRECATED and that is always defined when building GIMP.
Did you somehow undefine it?
Regards, Mitch
Helmut.
pdb-skip >*/
pdb-skip >*/
pdb-skip >*/
In file included from gimpbasetypes.h:26:0,                   from gimpbase-private.c:26: ../libgimpbase/gimpbaseenums.h:55:3: note: previous definition of   'GIMP_ADD_ALPHA_TRANSFER_MASK' was here     GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER, /**/
List address:    gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-develop er-list
List archives:   https://mail.gnome.org/archives/gimp-developer-list
Helmut Jarausch
2017-01-12 19:16:28 UTC (over 8 years ago)
Hi, I cannot compile the GIT version (today 16:00 GMT) Both, gimpbaseenums.hand gimpcompatenums.h define several enums of
the same name.
Regards, Mitch
Not intentionally, at least.
File gimpbase-private.c unconditionally includes
gimpbasetypes.h which includes gimpbaseenums.h and
gimpcompatenums.h
both, gimpbaseenums.h and gimpcompatenums.h declare uncondtionally
typedef enum {
GIMP_ADD_WHITE_MASK = GIMP_ADD_MASK_WHITE, GIMP_ADD_BLACK_MASK = GIMP_ADD_MASK_BLACK, GIMP_ADD_ALPHA_MASK = GIMP_ADD_MASK_ALPHA, GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER, GIMP_ADD_SELECTION_MASK = GIMP_ADD_MASK_SELECTION, GIMP_ADD_COPY_MASK = GIMP_ADD_MASK_COPY, GIMP_ADD_CHANNEL_MASK = GIMP_ADD_MASK_CHANNEL } GimpAddMaskTypeCompat;
and
typedef enum
GIMP_ADD_MASK_WHITE, /*< desc="_White (full opacity)" >*/
GIMP_ADD_MASK_BLACK, /*< desc="_Black (full transparency)" >*/
GIMP_ADD_MASK_ALPHA, /*< desc="Layer's _alpha channel" >*/
GIMP_ADD_MASK_ALPHA_TRANSFER, /*< desc="_Transfer layer's alpha channel" >*/
GIMP_ADD_MASK_SELECTION, /*< desc="_Selection" >*/ GIMP_ADD_MASK_COPY, /*< desc="_Grayscale copy of layer" >*/
GIMP_ADD_MASK_CHANNEL, /*< desc="C_hannel" >*/
#ifndef GIMP_DISABLE_DEPRECATED GIMP_ADD_WHITE_MASK = GIMP_ADD_MASK_WHITE, /*< skip, pdb-skip >*/
GIMP_ADD_SELECTION_MASK = GIMP_ADD_MASK_SELECTION, /*< skip, pdb-skip >*/
GIMP_ADD_COPY_MASK = GIMP_ADD_MASK_COPY, /*< skip, pdb-skip >*/
GIMP_ADD_CHANNEL_MASK = GIMP_ADD_MASK_CHANNEL /*< skip, pdb-skip >*/
#endif /* GIMP_DISABLE_DEPRECATED */ } GimpAddMaskType;
such that GIMP_ADD_MASK_WHITE is declared twice, indeed.
Michael Natterer
2017-01-12 19:58:11 UTC (over 8 years ago)
the same name.
Regards, Mitch
gimpcompatenums.h
typedef enum {
and
typedef enum
   GIMP_ADD_MASK_SELECTION,      /**/    GIMP_ADD_MASK_COPY,           /*< desc="_Grayscale copy of   layer"        >*/
   GIMP_ADD_MASK_CHANNEL,        /**/
pdb-skip >*/
pdb-skip >*/
pdb-skip >*/
   GIMP_ADD_ALPHA_TRANSFER_MASK = GIMP_ADD_MASK_ALPHA_TRANSFER, /**/    GIMP_ADD_SELECTION_MASK      = GIMP_ADD_MASK_SELECTION, /*< skip,
pdb-skip >*/
pdb-skip >*/
pdb-skip >*/
It's only declared twice if GIMP_DISABLE_DEPRECATED is *not* defined. Can you paste the output of "make V=1" of gimpbase-private.c please?
Regards, Mitch
