gimp_run_procedure() not working
gimp_run_procedure() not working cypher2k12 05 Jan 21:52
  gimp_run_procedure() not working Shlomi Fish 06 Jan 10:59
   gimp_run_procedure() not working cypher2k12 06 Jan 15:51
2017-01-05 21:52:26 UTC (about 8 years ago)
Hey guys, can somebody please tell me where I am going wrong? I am trying to use the 'gimp_run_procedure()' function to call the normal map plug-in, but I can not for the life of me get it to work. It builds without errors. Just doesn't work in GIMP.
Here is a snippet of the code:
gint n_return_vals;
gimp_run_procedure("plug-in-normalmap", &n_return_vals, GIMP_PDB_INT32, 1,
GIMP_PDB_IMAGE, param[1].data.d_image, GIMP_PDB_DRAWABLE, param[2].data.d_drawable, GIMP_PDB_INT32, 0,
GIMP_PDB_FLOAT, 0,
GIMP_PDB_FLOAT, 10,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_FLOAT, 0,
GIMP_PDB_DRAWABLE, param[2].data.d_drawable, GIMP_PDB_END
Shlomi Fish
2017-01-06 10:59:58 UTC (about 8 years ago)
Hi cypher2k12,
gint n_return_vals;
GIMP_PDB_FLOAT, 0,
This will likely pass the "0" as an integer instead of a float or double - you may need to do ((double)0).
Otherwise, see these pages - http://sscce.org/ ; http://catb.org/~esr/faqs/smart-questions.html ; https://github.com/shlomif/Freenode-programming-channel-FAQ/blob/master/FAQ.mdwn. You may wish to provide the sources for the SSCCE in a public git/etc. repository or a .zip file or whatever.
Shlomi Fish
GIMP_PDB_FLOAT, 10,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_INT32, 0,
GIMP_PDB_FLOAT, 0,
Shlomi Fish       http://www.shlomifish.org/
NSA Factoids - http://www.shlomifish.org/humour/bits/facts/NSA/
E‐mail, web feeds, and doing something productive — choose two.
Please reply to list if it's a mailing list post - http://shlom.in/reply .
2017-01-06 15:51:29 UTC (about 8 years ago)
Hi cypher2k12,
Shlomi Fish
Good news! That was the issue! I just had to stick the decimal point on the ends of the floating point numbers. God, that's some anal code there! I've gotten a bit too comfortable with C++! :D
Thank you! That was driving me mad!
