Plans to resolve hotkey conflicts?
13 of 14 messages available
Plans to resolve hotkey conflicts? C R 14 Dec 08:46
  Plans to resolve hotkey conflicts? Alexandre Prokoudine 14 Dec 09:14
   Plans to resolve hotkey conflicts? C R 14 Dec 10:10
    Plans to resolve hotkey conflicts? Jehan Pagès 17 Dec 04:37
     Plans to resolve hotkey conflicts? C R 17 Dec 11:30
      Plans to resolve hotkey conflicts? Jehan Pagès 17 Dec 11:53
       CABdJpS755N0742e27bc4eRfWjB... 17 Dec 12:42
        Plans to resolve hotkey conflicts? C R 17 Dec 12:42
         Plans to resolve hotkey conflicts? Simon Budig 18 Dec 16:11
          Plans to resolve hotkey conflicts? C R 18 Dec 17:43
           Plans to resolve hotkey conflicts? Simon Budig 18 Dec 17:59
            Plans to resolve hotkey conflicts? C R 18 Dec 18:16
      Plans to resolve hotkey conflicts? Jehan Pagès 17 Dec 13:26
       Plans to resolve hotkey conflicts? C R 17 Dec 13:49
C R
2016-12-14 08:46:35 UTC (over 8 years ago)
The Colour menu has again become a mess of conflicting hotkeys. Can someone reassign/resolve them?
Probably a good idea to get rid of some of the duplicate functions like "drop shadow" and the proliferation of duplicate desaturate actions. :)
If help is needed picking the best versions to keep, let me know. I'm happy to help in any way that I can. I assume the non-gegl based actions are going away soonish?
Thanks!
-C
2016-12-14 09:14:46 UTC (over 8 years ago)
Done three weeks ago:
https://git.gnome.org/browse/gimp/commit/?id=2a232398c4ad5a3108b5ad75be7bc8ef5d98e6fb
Alex
C R
2016-12-14 10:10:29 UTC (over 8 years ago)
Thanks Alex.
And I'm still getting overlaping hotkeys with:
s - Hue/Saturation, Colourise e - Desaturate, Color Temperature
x - Exposure, Retinex
I'm running the gimp-edge repo. The current one is:
gimp 2.9.5~58-0y0~ppa~9f15ad6
It also seems there is a bug that forces the user to press the over arrow to access the hotkeys for sub-menus. For example, the key combination alt+c > e > d should call up the desaturate dialog, but the user must use this combination instead: alt+c > e > right arrow > d.
Is this possibly a GTK bug?
All the styling on the new menus looks great btw.
Thanks. -C
Alex _______________________________________________ gimp-developer-list mailing list
Jehan Pagès
2016-12-17 04:37:58 UTC (over 8 years ago)
On Wed, Dec 14, 2016 at 11:10 AM, C R wrote:
Thanks Alex.
Ok so it seems you are talking of something different from what Alexandre linked. This commit was about duplicate shortcuts. You are talking about what GTK+ calls "mnemonics", which is this underlined character on menu items or buttons. This commit did indeed nothing related to mnemonics.
I don't really know what is the deal with mnemonics because that's a real mess by design. Indeed having duplicated mnemonics is hard to check since a same action can be used in various contexts (different menus, dialogs…). In one case, it may be fine, but in others, it won't.
I think I read someone saying that maybe GTK+ would be getting away from mnemonics in the long run but I can't find any actual reference to this (apart from the fact that it is not possible to see them by default in GTK+3 apparently, without pressing Alt). So I don't know.
That's another case which shows the problem with mnemonics: by default, the label is "Colori_ze" (with a mnemonic on 'z'), but the translator changed it to 's' (obviously you are using UK English). So there is no conflicts in US English, but there is one in UK English. This is too much of a burden on translators to be able to change mnemonics (so should they be expected to check every place where they are used, as well as developers?).
Anyway I don't really have good answers for you. You can try and open bug reports for the conflicts you find and we'll try to fix them. But we likely won't be 100% sure that we won't create new mnemonics conflicts somewhere else by fixing them in this specific menu. And the ones on translated strings will be even more annoying. Maybe we should ask translators to not change mnemonics even when the translation does not have the letter? (they would add a "(z)" at the end of the string. That's what they do in languages with indirect input like Japanese, though it could feel like a stepback for a lang such as UK English)
Jehan
e - Desaturate, Color Temperature x - Exposure, Retinex
Is this possibly a GTK bug? All the styling on the new menus looks great btw.
Thanks. -C
ZeMarmot open animation film
http://film.zemarmot.net
C R
2016-12-17 11:30:06 UTC (over 8 years ago)
Thanks for the explanation. I don't imagine it's possible to avoid them all, however could you fix the ones I've highlighted? I guess a workaround would be to change to the American English version? Seems not a good solution.
Another fix would be to leave the mnemonics as they are, and just make it possible to hit the same letter twice to get to the next one. - This works the first time, but it switches which entry is highlighted each time the combination is used. If it were simply consistent each time I'd consider it a non-issue.
Can this behaviour be fixed?
Thanks. -C
Thanks Alex.
Jehan
Thanks. -C
Alex
developer-list
developer-list
Patreon: https://patreon.com/zemarmot Tipeee: https://www.tipeee.com/zemarmot
Jehan Pagès
2016-12-17 11:53:40 UTC (over 8 years ago)
I think this would be the better fix. But then what of this case: - 'a' is mnemonic for 'submenu 1'
- 'a' is mnemonic for 'item 1' under 'submenu 1' - 'a' is mnemonic for 'item 2' (same level as submenu 1)
Hitting 'a' highlight 'submenu 1'. Should hitting again 'a' highlight 'item 2' on the same level or enter inside 'submenu 1' and highlight 'item 1'?
Of course, if hitting right arrow is mandatory to go inside the submenu, that's not a problem, but since you felt it was a problem earlier, I just wanted to raise the issue.
Second issue is that you usually want to have an item be directly run (and not just highlighted) when it is a finale item. Otherwise should we also hit Enter to activate?
Everything can be done, but since that's in GTK+:
- GTK+ devs must agree with the change of behavior. - This cannot be for GIMP 2.10 because GTK+ is stable and don't accept new features/change of behavior. Also GTK+3 itself just went stable so that means it probably won't be doable for GIMP 3 even.
Jehan
Thanks.
-C
Thanks Alex.
Jehan
Thanks. -C
C R
2016-12-17 12:42:42 UTC (over 8 years ago)
I mean, I really don't care as long as it's consistent, and it never has been in the past, for as long as I have used GIMP.
I should be able to hit a sequence of hotkeys to get to sub menu items, and doing it again should get me to the same function each and every time I perform them.
Reducing the number of hotkeys necessary to do each action would be nice, but I'll take consistency over less keys any day because it takes longer to see and figure out which overlaping mnemonic gtk decided to randomly choose this time. It may seem like a small thing but it's really crippling to workflow.
Thanks for your help. -C
Jehan
Thanks.
-C
Thanks Alex.
Jehan
Thanks. -C
Alex
Jehan Pagès
2016-12-17 13:26:46 UTC (over 8 years ago)
By the way,
You should open bug reports. I don't have time (or the will) to do this just now, and I will have forgotten about this in a few hours (and in a few days, this email will be lost in the bottom of my mailbox).
If you want bugs to leave a trace and not be forgotten, you should open bug reports. They can then also be dealt by other developers (not only me) later on so you improve chances of seeing this being taken care of.
Thanks.
Jehan
Thanks.
-C
Thanks Alex.
Jehan
Thanks. -C
C R
2016-12-17 13:49:35 UTC (over 8 years ago)
I will, I was just hoping it might be a quick fix. Thanks.
-C
On 17 Dec 2016 1:27 pm, "Jehan Pagès" wrote:
By the way,
Thanks.
Jehan
Thanks.
-C
Thanks Alex.
Jehan
Thanks. -C
Alex
Simon Budig
2016-12-18 16:11:09 UTC (over 8 years ago)
Uh. In what way isn't that the case currently?
GTK+ cycles through all the "conflicting" mnemonics. So (for british english) ALT-C, s, s consistently brings you to "Colouri_se".
I usually don't use the mnemonic-based menu navigation, so I might be missing something...
Bye,
Simon
simon@budig.de              http://simon.budig.de/
C R
2016-12-18 17:43:00 UTC (over 8 years ago)
Try Alt-C, s for hue/saturation
Then try it again after you complete the hue saturation action On the second run alt-C, s skips to Colourise
Thanks. -C
Bye,
Simon
simon@budig.de http://simon.budig.de/ _______________________________________________ gimp-developer-list mailing list
Simon Budig
2016-12-18 17:59:42 UTC (over 8 years ago)
Oh, indeed. That feels stupid.
Bye, Simon
C R
2016-12-18 18:16:21 UTC (over 8 years ago)
It's been like that for ages. I'll go ahead and file a bug report, if no one wants to fix it, or can't quickly.
Thanks. -C
Bye, Simon
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp- developer-list
