broken threshold
broken threshold Carol Spears 07 Nov 15:05
  broken threshold Carol Spears 08 Nov 03:40
Carol Spears
2016-11-07 15:05:19 UTC (over 8 years ago)
broken threshold
gimp-context-set-sample-threshold and gimp-context-set-sample-threshold-int are giving me Execution Errors since commit 3307c719663dd3aefb5722ad5cdb7faf03bcfdaf
It might be me. I might have an int where a float is wanted.
It might not be me though.
Thanks, carol
Carol Spears
2016-11-08 03:40:31 UTC (over 8 years ago)
broken threshold
My execution error is when I use gimp-drawable-desaturate and maybe it is going to happen with gimp-drawable-select-color.
I suspect it is something in the enums.
When I was poking around within GIMP's py-enums, I noticed that there was a change in them. LUMINOSITY has changed to LUMINANCE. I guess I have been around a long while because I was told it was better to use the "wordy" enum and not the number for scripting.
It was nice to see that threshold was fixed. I was always uncertain how to use the procedure command given how it is used via the gui.
Thanks, carol
