drag and drop
16 of 16 messages available
drag and drop black-explorer 30 Oct 12:47
  drag and drop Michael Schumacher 30 Oct 12:54
   drag and drop black-explorer 30 Oct 13:22
    drag and drop Patrick Shanahan 30 Oct 22:46
     drag and drop Partha Bagchi 30 Oct 22:53
   drag and drop Steve Kinney 30 Oct 13:23
    drag and drop Michael Schumacher 30 Oct 14:21
     drag and drop Ofnuts 30 Oct 15:02
  drag and drop Partha Bagchi 30 Oct 15:47
   drag and drop black-explorer 30 Oct 17:06
    drag and drop Partha Bagchi 30 Oct 22:50
     drag and drop black-explorer 03 Nov 11:00
      drag and drop Mark Morin 04 Nov 02:32
       drag and drop Jehan Pagès 05 Nov 02:08
        drag and drop Ofnuts 05 Nov 14:12
         drag and drop Jehan Pagès 07 Nov 04:26
2016-10-30 12:47:16 UTC (over 8 years ago)
drag and drop
As the subject suggests: drag and drop of an image over the gimp icon would be an intuitive and good feature.
2016-10-30 12:54:12 UTC (over 8 years ago)
drag and drop
Am 30.10.2016 um 13:47 schrieb black-explorer:
And what should happen if someone does this?
Please re-read your message, assume that others do not know what you are thinking about, and elaborate.
2016-10-30 13:22:49 UTC (over 8 years ago)
drag and drop
Am 30.10.2016 um 13:47 schrieb black-explorer: And what should happen if someone does this?
well, my suggestion is that the image file opens up inside gimp when i drag and drop it onto the gimp icon.
2016-10-30 13:23:13 UTC (over 8 years ago)
drag and drop
Just guessing that means, drag and drop an image file to a GIMP start icon on a Windows desktop. I seem to remember that XP would do that with files dropped on program icons. If so, that's an operating system window manager thing, that the GIMP can't influence one way or another.
2016-10-30 14:21:13 UTC (over 8 years ago)
drag and drop
Am 30.10.2016 um 14:23 schrieb Steve Kinney:
There might be some sort of entry point applications have to implement to make this to work.
2016-10-30 15:02:37 UTC (over 8 years ago)
drag and drop
Works out f the box on WinXP if the OP's "icon" is a shortcut to Gimp. IIRC you can even define a shortcut for a .BAT and have it process files that way...
Partha Bagchi
2016-10-30 15:47:51 UTC (over 8 years ago)
drag and drop
On my builds when you do that on Windows, it will open that image with GIMP. Are you not getting that behavior?
Thanks, Partha
-- black-explorer (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
2016-10-30 17:06:46 UTC (over 8 years ago)
drag and drop
Thanks, Partha
No. I'm on Windows 10 HOME.
Patrick Shanahan
2016-10-30 22:46:12 UTC (over 8 years ago)
drag and drop
* black-explorer [10-30-16 18:42]:
Then you must configure WINDOWS to do that. It is not a function of gimp but your chosen operating system.
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Partha Bagchi
2016-10-30 22:50:06 UTC (over 8 years ago)
drag and drop
Thanks, Partha
What do you mean "No"? Can you please explain?
I said that on Windows (in my case Windows 10, 64-bit), GIMP will open the image if you drag the image on top of the GIMP icon on your desktop. The additional point I mentioned is that it is with respect to my builds available at my website.
Partha Bagchi
2016-10-30 22:53:37 UTC (over 8 years ago)
drag and drop
drag and
This been a Windows function for quite sometime... There is nothing to
"configure".
2016-11-03 11:00:16 UTC (over 8 years ago)
drag and drop
No, I don't have the drag and drop behaviour in my Windows 10 / Gimp 2.8.18 setup.
Mark Morin
2016-11-04 02:32:32 UTC (over 8 years ago)
drag and drop
Works fine on my windows 10 64bit using Partha's 2.9 build. Drag the image file over the icon and I see "open with ....."
Jehan Pagès
2016-11-05 02:08:13 UTC (over 8 years ago)
drag and drop
I see several messages saying it works using Partha's build. Does it mean it does not work using the upstream build from gimp.org? If so, do we have to do something to have this working out of the box on our official build, and could you tell us what, please? Thank you.
Jehan
ZeMarmot open animation film
http://film.zemarmot.net
2016-11-05 14:12:20 UTC (over 8 years ago)
drag and drop
Jehan
Works OK on XP with the "official" builds...
Jehan Pagès
2016-11-07 04:26:47 UTC (over 8 years ago)
drag and drop
Jehan
Thanks.
Jehan
