Redesign "move selection"?
10 of 10 messages available
Redesign "move selection"? lofreq 20 Oct 17:30
  Redesign "move selection"? Ofnuts 20 Oct 23:06
   Redesign "move selection"? Michael Schumacher 20 Oct 23:15
    Redesign "move selection"? Alexandre Prokoudine 20 Oct 23:41
     Redesign "move selection"? Richard 21 Oct 00:29
      Redesign "move selection"? Liam R. E. Quin 21 Oct 03:09
       Redesign "move selection"? Ofnuts 21 Oct 11:47
        Redesign "move selection"? Richard 22 Oct 00:35
      Redesign "move selection"? Akkana Peck 22 Oct 17:43
   Redesign "move selection"? lofreq 03 Nov 22:16
2016-10-20 17:30:55 UTC (over 8 years ago)
I am a new user, but I know exactly what I need from GIMP. I tested out my workflow from start to finish the other day, and while most of my flubs were from inexperience, a lost a lot of time to trying to move selections around. I did some research and found that many others share similar frustrations with how unintuitive the move tool is in this regard. Is there any talk of redesigning it?
I also encountered another problem with the feature that I did not see addressed anywhere else, which may be actually a bug. So what I use it for (and have with great ease and efficiency in Photoshop) is in "hand" lettering my comics - basically, I will write out the contents of the word balloons in a template file, copy and paste them into my pages, and fine-tune their placement. These wind up being hand-written letters on transparent layers. The dimensions of these layers are much smaller than that of the page itself. However, I usually need to move individual words or lines of text around once I've pasted it on top of the word balloon, and I've found that I cannot move the selection/floating layer beyond the borders of the original layer. In fact, it disappears, functioning like a mask. I know the current solution is to copy/paste the selection content into a new layer, but that seems excessive, given that sometimes I have to move dozens of words or lines around on any given page, and sometimes by only a few pixels, especially in the case of tweaking the spacing between individual letters.
So my two questions are as follows, I guess:
1. Is it at all possible to just click and drag selections? Why is it necessary to hold down ctrl+alt to accomplish this?
2. Is the masking behavior of floating layers a bug or a feature? Either or, it needs fixing. Or at the very least a toggle, because I can't imagine a single instance where that would be preferable to just using an actual mask.
2016-10-20 23:06:58 UTC (over 8 years ago)
Because click without key modifiers has other uses. Maybe you shouldn't be using
selections on a bigger layer, and instead be using a text layer for each piece of text.
What you want is Layer>Layer to image size.
2016-10-20 23:15:09 UTC (over 8 years ago)
Ages ago, click-drags did move the selection content without additional modifier keys.
But we got complaints that it is far too easy to accidentally move this selected content by minute amounts and not even notice this. So it got changed to the current behavior.
2016-10-20 23:41:02 UTC (over 8 years ago)
And I can't help myself wondering if that was a case of a vocal minority affecting a design decision that now irritates a vocal majority :)
Alex
Richard
2016-10-21 00:29:43 UTC (over 8 years ago)
From: gimp-user-list  on behalf of Alexandre Prokoudine
Sent: Thursday, October 20, 2016 4:41 PM
To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] Redesign "move selection"?
> modifier keys.
majority :)
Alex
Oh, boy, THIS subject.  Where my workflow is concerned this was the BIGGEST breaking change GIMP ever made -- yes, even bigger than when 2.8 split Save and Export.  (And we remember all the complaints over that, right?)
I am one of those where when I no-modifier click and drag a selection my preferred action is to pick up those pixels and move them around (rather than shifting the mask).  It is ... a minimum of annoying that we have zero means of configuring GIMP to match our workflow in this respect.
While the decision to change it was definitely made in good faith, I wonder if it was made largely because (1) it was easy to remap how the selection tools handle modifiers, and (2) a lack of proposed alternatives?
The first (and most obvious) alternative is to make this behavior a user configurable option in the GIMP preferences -- like we already have for whether the Move tool should default to picking to moving (I prefer picking).
A second alternative would be to give the selection tools a sensitivity threshold -- i.e. you must click and drag the cursor a minimum # of screen pixels before the tool will start the drag action.  I wonder if this could have solved most of those accidental microadjustments people complained about in GIMP 2.2 without introducing a breaking change....
-- Stratadrake
strata_ranger@hotmail.com
Liam R. E. Quin
2016-10-21 03:09:31 UTC (over 8 years ago)
Fewer options better. Easier to learn. Easier to help people. Easier to test.
This might work or might be irritating to people who want to move by one pixel.
I wish we had on-click, on-drag script hooks so that this choice could be scripted. Imagine making the default be to move and use resynthesizer to fill in the missing details!
Without that, seems to me the current situation isn't bad, and that there have been fewer complaints this way round, even though I can see it's not ideal.
Liam [ankh]
Liam R. E. Quin
The best thing about being a slave is not having a mortgage to pay.
Oh, wait... I'm doing this wrong.
2016-10-21 11:47:11 UTC (over 8 years ago)
AFAIK this is settable in Windows and Linux (5px in the KDE default settings), together with a minimum click-down delay. I don't know if Gimp uses the system's drag notification or if it cooks its own, but anyway because of this people are used to "shake" before dragging on short distances.
Me too. Even more if this doesn't impact the mouse response time :)
The plain click-drag is used fro other things. In ellipse and rectangle selection, this moves the selection mask...
Richard
2016-10-22 00:35:18 UTC (over 8 years ago)
Did someone's email get missed or am I just not seeing it?
From: gimp-user-list on behalf of Ofnuts Sent: Friday, October 21, 2016 4:47 AM To: gimp-user-list@gnome.org
Windows Click and drag thresholds aren't (ever?) visibly reconfigurable, you have to edit the system registry to change it. The default threshold is 4px, and GIMP definitely does NOT acknowledge this (click-drag initiates at 1px). Can we bugfile this? And just add it to the long laundry list of Windows OS settings GIMP doesn't respect (Windows native filepicker, Alt to activate the menubar...)
[tangent] ...though to be fair, GIMP uses Alt as a modifier in its own right so having Alt do double duty between modifier key and menubar access is rife with problems (it's actually easy to control whether Alt is used as a modifier or for menu access -- the real problem is writing the logic that decides WHEN the Alt key should cause which response). Besides, I wager most people are used to accessing menus via click/tap anyway; I know I am.
The plain click-drag is used for other things. In ellipse and rectangle selection, this moves the selection mask...
Did it do that in GIMP 2.2 (before the plainclick-and-drag behavior got changed) ? If not then the present behavior actually is more consistent across all select tools, but some alternative to the current behavior would still be nice for those of us who need to move selected content around a lot.
(I also have my own complaints about the Ellipse and Rectangle selects specifically, but let's not go there.)
Akkana Peck
2016-10-22 17:43:49 UTC (over 8 years ago)
Richard writes:
Just so you hear from the other side ...
For me, the new selection tools, where drag moved the selection mask (not its contents) was a huge win. I was forever frustrated at how hard it was to move a selection, especially with ellipse selections where you can't tell when you start dragging where the top left of the ellipse will end up. I remember always having to switch to the Move tool, change mode to "Move selection", drag, change modes back then change tools. I was fairly new then, so maybe there was an easier way via a modifier key that I just never discovered.
I very seldom want to move the contents of the selection. I edit a lot of photos, and on a photo that just leaves a ragged white hole behind. In the rare event that I want to move just part of a transparent layer), it's easy, Select->Float (Shift-Ctrl-L).
I'm not saying Richard is wrong -- I know he's not alone, I've heard enough people who miss the old behavior. Just that for me, the current UI is much better, and that it's a lot easier now to move the selection contents than it used to be to move the selection. If the default ever changes to float-and-move, please include an easy and discoverable way to move the selection mask without needing to change tools or tool options.
In my case it had nothing to do with threshold; it was more the lack of an easy, intuitive way to move the mask.
...Akkana
2016-11-03 22:16:37 UTC (over 8 years ago)
Because click without key modifiers has other uses. Maybe you shouldn't be using selections on a bigger layer, and instead be using a text layer for each piece of text.
I write my text by hand using a tablet and template file. Sorry, I didn't clarify this originally. Anyways, in a large paragraph, you can understand how that might be like trying to arrange magnetic poetry... but having to go through the rigamarole in order to move any individual piece.
Obviously, making this adjustable would be ideal. How hard could it be to throw in a checkbox someplace? And if the functionality was already there in a previous version, then it wouldn't take too much to bring it back again + toggle.
Arrow keys?
Floating layers are the bane of my existence. I want to nudge a selection this way or that for half a second, not commit it to a whole new layer (and then ctrl+h immediately for every single minute adjustment; and don't get me started on why that's got to be a different command than merging a normal layer) every time. When you're moving 20 things around in the span of about 2 minutes, that gets cumbersome very, very quickly.
