babl HCY color space extension
babl HCY color space extension SBP 16 Oct 03:42
  babl HCY color space extension Alexandre Prokoudine 16 Oct 05:05
SBP
2016-10-16 03:42:36 UTC (over 8 years ago)
Hi there!
I'm interested in using babl as a color space converter for a software of mine. I find the HCY (hue, chroma, luma) color space useful, so I decided to include it in babl in order to migrate my color conversion codebase to babl.
The extension is based on the work and code of Kuzma Shapran (https://code.google.com/archive/p/colour-space-viewer), and mimics the HSV/HSL extensions. I have made a test program as well, using values from the original implementation passed through babl's gamma-to-linear conversion routines.
I'd like to submit this extension, but don't know how. Should I send it as an attachment, or perhaps make a pull request from git?
A couple of points though.
The original implementation uses the Rec. 601 luma coefficients, and as I'm aware babl prefers the sRGB Y values for the D50 illuminant (rgb-constants.h). Should I use these instead of the original ones?
While reading the code for the HSV extension I noticed a little possible improvement. Instead of computing x with fabs and fmod, given that we have cases for each hue sector, it's possible to predict the result of these operations and avoid using those functions, which I suppose would be faster. Already tested with the included test. Sounds ok? How do I post the patch?
Cheers!
Sirius.
PS. It would be cool to have support in babl for all kinds of color spaces, thus becoming the standard for color conversions in C (as I find this niche quite barren...). Is this consistent with the project goals? So as to make more extensions ;) The list at https://github.com/scijs/color-space looks rather tasty!
2016-10-16 05:05:35 UTC (over 8 years ago)
16 окт. 2016 г. 7:43 пользователь "SBP" написал:
Git-formatted patch submitted via bugzilla.gnome.org for the 'babl' product would do. Thank you!
Alex
