Colour of guides
Colour of guides Kevin Payne 01 Oct 11:07
Kevin Payne
2016-10-01 11:07:44 UTC (over 8 years ago)
Colour of guides
I'm trying to answer a question for someone else: http://gimpchat.com/viewtopic.php?f=8&t=14637
where they are trying to change the colour of the guides.
I've tried looking in the code to find out where and how the colours are set, but I've drawn a blank as I personally find the code extremely difficult to follow sometimes. (I think I found the cairo instruction to draw the line but I can't see where cairo is told which drawing style to use)
So the questions are
Are the colours hard-coded? If not can they be set using the theme? and if so what ids should be used?
regards
Kevin
