Gegl# issues
Gegl# issues Mark Probst 08 May 22:00
Gegl# issues Øyvind Kolås 09 May 10:16
Mark Probst
2007-05-08 22:00:44 UTC (almost 18 years ago)
Gegl# issues
Hi!
I've just built Gegl# from SVN, and to get the view test running, I had to make the following change:
Index: gegl/gegl-init.c =================================================================== --- gegl/gegl-init.c (revision 1454) +++ gegl/gegl-init.c (working copy) @@ -62,7 +62,7 @@
if (gegl_initialized)
return;
- g_thread_init (NULL);
+ if (!g_thread_supported()) g_thread_init (NULL);
/* If any command-line actions are ever added to GEGL, then the * commented out code below should be used. Until then, we simply
Apparently the GThread system is already initialized before the Gegl initialization, and it must only be initialized once.
Mark
Øyvind Kolås
2007-05-09 10:16:19 UTC (almost 18 years ago)
Gegl# issues
Change commited to SVN.
/Øyvind K.
