webp format?
webp format? Owen Cook 21 Aug 10:01
  webp format? Elle Stone 21 Aug 20:15
   webp format? Partha Bagchi 21 Aug 21:21
   webp format? Elle Stone 21 Aug 23:27
Owen Cook
2016-08-21 10:01:24 UTC (over 8 years ago)
webp format?
I noticed in the latest git a lot of stuff which suggests that gimp should open webp, and export to webp.
Is this correct, and if so how do you activate it. Currently I get "Unknown file type" on opening, and webp is not in the list of export formats.
TIA
Owen
Elle Stone
2016-08-21 20:15:56 UTC (over 8 years ago)
webp format?
On a possibly related note, libwebp-0.4.2 is installed on my system (Gentoo Linux), but when configuring GIMP this message is printed to the terminal: WebP: no (WebP not found)
Thinking 0.4.2 might be too old, I downloaded libwebp-0.5.1 from https://developers.google.com/speed/webp/docs/compiling#building, and installed it in /usr/local, and then re-installed babl/gegl/libmypaint/gimp starting from "./autogen.sh". But GIMP still isn't finding WebP. GEGL finds WebP, but GIMP doesn't.
Is there some other library that might be required before GIMP can find WebP on the system? Or a magic command that says "look here"?
Best, Elle
In case it's relevant, here's the configuration summary from compiling libwebp-0.5.1:
WebP Configuration Summary --------------------------
Shared libraries: yes Static libraries: yes
Threading support: yes
libwebp: yes
libwebpdecoder: no
libwebpdemux: no
libwebpmux: no
libwebpextras: no
Tools:
cwebp : yes
Input format support
JPEG : yes
PNG : yes
TIFF : yes
WIC : no
dwebp : yes
Output format support
PNG : yes
WIC : no
GIF support : yes
anim_diff : no
gif2webp : no
webpmux : no
vwebp : no
Partha Bagchi
2016-08-21 21:21:25 UTC (over 8 years ago)
webp format?
Elle,
Works fine here on my Mac McGimp latest build as available on my website. I got the sample images from https://developers.google.com/speed/webp/gallery1
Thanks, Partha
Best, Elle
libwebp: yes
libwebpdecoder: no
libwebpdemux: no
libwebpmux: no
libwebpextras: no
Tools:
cwebp : yes
JPEG : yes
PNG : yes
TIFF : yes
WIC : no
dwebp : yes
PNG : yes
WIC : no
GIF support : yes
anim_diff : no
gif2webp : no
webpmux : no
vwebp : no
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman /listinfo/gimp-developer-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
Elle Stone
2016-08-21 23:27:41 UTC (over 8 years ago)
webp format?
libwebp: yes
libwebpdecoder: no
libwebpdemux: no
libwebpmux: no
libwebpextras: no
Tools:
cwebp : yes
JPEG : yes
PNG : yes
TIFF : yes
WIC : no
dwebp : yes
PNG : yes
WIC : no
GIF support : yes
anim_diff : no
gif2webp : no
webpmux : no
vwebp : no
Hmm, there is the problem:
0050-INSTALL-libwebp-must-be-built-with-enable-libwebpmux.patch
For whatever reason libwebp wasn't built with webpmux. Perhaps that's an option that can be configured when installing libwebp.
Best, Elle
