bump map crashes
bump map crashes Alexander Rabtchevich 15 May 11:08
2016-05-15 11:08:32 UTC (almost 9 years ago)
bump map crashes
Hello
A build from 2016.05.10 crushes when closing the bump map plugin (cancel) or selecting an input image.
With respect, Alexander Rabtchevich
Program received signal SIGSEGV, Segmentation fault. 0x00007ffff4454b20 in ?? () from
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (gdb) thread apply all bt full
Thread 6 (Thread 0x7fffbe1ea700 (LWP 7860)): #0 pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:185 No locals.
#1 0x00007ffff41cbbf7 in g_cond_wait () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#2 0x00007ffff50e0441 in ?? () from /usr/lib/x86_64-linux-gnu/libgegl-0.3.so.0 No symbol table info available.
#3 0x00007ffff41aef05 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#4 0x00007ffff35a5182 in start_thread (arg=0x7fffbe1ea700) at pthread_create.c:312
__res =
pd = 0x7fffbe1ea700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736383067904, 9110283720951581584, 1, 36660032, 140736383068608, 140736383067904, -9110422524556489840, -9110258187989300336},
mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
---Type to continue, or q to quit--- pagesize_m1 =
sp =
freesize =
__PRETTY_FUNCTION__ = "start_thread" #5 0x00007ffff32d247d in clone ()
at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111 No locals.
Thread 4 (Thread 0x7fffbffff700 (LWP 7846)): #0 0x00007ffff32c512d in poll () at ../sysdeps/unix/syscall-template.S:81 No locals.
#1 0x00007ffff4189fe4 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#2 0x00007ffff418a0ec in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#3 0x00007ffff418a129 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#4 0x00007ffff41aef05 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a5182 in start_thread (arg=0x7fffbffff700) at pthread_create.c:312
__res =
---Type to continue, or q to quit--- pd = 0x7fffbffff700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736414611200, 9110283720951581584, 1, 0, 140736414611904, 140736414611200,
-9110424458902385776, -9110258187989300336}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
__PRETTY_FUNCTION__ = "start_thread" #6 0x00007ffff32d247d in clone ()
Thread 2 (Thread 0x7fffe840c700 (LWP 7844)): #0 0x00007ffff32c512d in poll () at ../sysdeps/unix/syscall-template.S:81 No locals.
#2 0x00007ffff418a30a in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 ---Type to continue, or q to quit--- No symbol table info available.
#3 0x00007ffff4990336 in ?? () from /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a5182 in start_thread (arg=0x7fffe840c700) at pthread_create.c:312
__res =
pd = 0x7fffe840c700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140737089947392, 9110283720951581584, 1, 0, 140737089948096, 140737089947392,
-9110242976669906032, -9110258187989300336}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
Thread 1 (Thread 0x7ffff7fb0a40 (LWP 7840)): #0 0x00007ffff4454b20 in ?? ()
from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#1 0x00007ffff44593b8 in g_closure_invoke () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#2 0x00007ffff446ad3d in ?? ()
#3 0x00007ffff4472a29 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#4 0x00007ffff4473212 in g_signal_emit_by_name () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#5 0x00007ffff44593b8 in g_closure_invoke () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#6 0x00007ffff446ad3d in ?? ()
---Type to continue, or q to quit--- #7 0x00007ffff4472a29 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#8 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#9 0x00007ffff445d725 in ?? ()
#10 0x00007ffff445cff2 in ?? ()
#11 0x00007ffff4460ba5 in g_object_set_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#12 0x00007ffff4461397 in g_object_set () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#13 0x00007ffff4186648 in g_list_foreach () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#14 0x0000000000502874 in ?? ()
---Type to continue, or q to quit--- #15 0x0000000000527a81 in gimp_tool_control () No symbol table info available.
#16 0x00007ffff445b611 in g_cclosure_marshal_VOID(int0_t, void) () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#17 0x00007ffff44595e7 in ?? ()
#18 0x00007ffff4472088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#19 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#20 0x00007ffff44593b8 in g_closure_invoke () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#21 0x00007ffff446ad3d in ?? ()
#22 0x00007ffff4472a29 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
---Type to continue, or q to quit--- #23 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#24 0x00007ffff44595e7 in ?? ()
#25 0x00007ffff4472088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#26 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#27 0x00007ffff75a7585 in ?? ()
from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#28 0x00007ffff44595e7 in ?? ()
#29 0x00007ffff4472088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#30 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 ---Type to continue, or q to quit--- No symbol table info available.
#31 0x00007ffff75a64d9 in ?? ()
#32 0x00007ffff7648815 in ?? ()
#33 0x00007ffff44593b8 in g_closure_invoke () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#34 0x00007ffff446aafb in ?? ()
#35 0x00007ffff44726f9 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#36 0x00007ffff4472ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#37 0x00007ffff7758684 in ?? ()
#38 0x00007ffff7646fc4 in gtk_propagate_event () ---Type to continue, or q to quit--- from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#39 0x00007ffff764737b in gtk_main_do_event () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#40 0x00007ffff72c13ec in ?? ()
from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 No symbol table info available.
#41 0x00007ffff4189e04 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#42 0x00007ffff418a048 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#43 0x00007ffff418a30a in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#44 0x000000000048e6f5 in app_run () No symbol table info available.
#45 0x000000000048e0c8 in main ()
