[PATCH 1/1] video-degradation: Don't crash when CL build fails
| [PATCH 1/1] video-degradation: Don't crash when CL build fails | Jan Vesely | 14 May 23:04 |
| [PATCH 1/1] video-degradation: Don't crash when CL build fails | Øyvind Kolås | 15 May 12:12 |
| [PATCH 1/1] video-degradation: Don't crash when CL build fails | Jan Vesely | 15 May 20:03 |
| [PATCH 1/1] video-degradation: Don't crash when CL build fails | pippin@gimp.org | 15 May 20:29 |
| video-degradation test (was: Re: [PATCH 1/1] video-degradation: Don't crash when CL build fails) | Jan Vesely | 16 May 18:24 |
Signed-off-by: Jan Vesely
operations/common/video-degradation.c | 16 ++++++++++------
1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/operations/common/video-degradation.c b/operations/common/video-degradation.c
index 29197ff..5b84e2a 100644
--- a/operations/common/video-degradation.c
+++ b/operations/common/video-degradation.c
@@ -201,13 +201,17 @@ cl_process (GeglOperation *operation,
const size_t gbl_size[2] = {roi->width, roi->height};
const size_t gbl_off[2] = {roi->x, roi->y};
cl_int cl_err = 0;
+ cl_mem filter_pat = NULL;
- cl_mem filter_pat = gegl_clCreateBuffer (gegl_cl_get_context (),
- CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR,
- pattern_width[o->pattern] *
- pattern_height[o->pattern] * sizeof(cl_int),
- (void*)pattern[o->pattern],
- &cl_err);
+ if (!cl_data)
+ goto error;
+ filter_pat = gegl_clCreateBuffer (gegl_cl_get_context (),
+ CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR,
+ pattern_width[o->pattern] *
+ pattern_height[o->pattern] * sizeof(cl_int),
+ (void*)pattern[o->pattern],
+ &cl_err);
CL_CHECK;
cl_err = gegl_cl_set_kernel_args (cl_data->kernel[0],
sizeof(cl_mem), &in_buf,
2.5.5
Please use bugzilla which is GEGLs normal patch/bug handling system. I've pushed these changes to git master - albeit with slightly deteriorated meta data since the diffs were manually incorporated.
/pippin
operations/common/video-degradation.c | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)diff --git a/operations/common/video-degradation.c b/operations/common/video-degradation.c index 29197ff..5b84e2a 100644
--- a/operations/common/video-degradation.c +++ b/operations/common/video-degradation.c @@ -201,13 +201,17 @@ cl_process (GeglOperation *operation, const size_t gbl_size[2] = {roi->width, roi->height}; const size_t gbl_off[2] = {roi->x, roi->y}; cl_int cl_err = 0;
+ cl_mem filter_pat = NULL;- cl_mem filter_pat = gegl_clCreateBuffer (gegl_cl_get_context (), - CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR, - pattern_width[o->pattern] * - pattern_height[o->pattern] * sizeof(cl_int), - (void*)pattern[o->pattern], - &cl_err); + if (!cl_data)
+ goto error;
+ filter_pat = gegl_clCreateBuffer (gegl_cl_get_context (), + CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR, + pattern_width[o->pattern] * + pattern_height[o->pattern] * sizeof(cl_int), + (void*)pattern[o->pattern], + &cl_err); CL_CHECK;
cl_err = gegl_cl_set_kernel_args (cl_data->kernel[0], sizeof(cl_mem), &in_buf, --
2.5.5_______________________________________________ gegl-developer-list mailing list
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-developer-list
thank you, I'll use bugzilla next time. I assumed everybody just uses git am.
The unexpected part is that the test now passes, despite not doing any processing. I have attached diff between reference and OpenCL result. note that CPU version of the algorithm produces the exact same picture as OpenCL (which did no processing)
Jan
/pippin
- pattern_width[o-pattern] *
- pattern_height[o-
- (void*)pattern[o-
pattern],
+ goto error;
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-devel oper-list
Jan Vesely
We do use git am formatted patches - but attached to bugs in bugzilla instead of sent to the mailinglist - they might linger for a while, but at least not be forgotten like messages to the mailinglist more readily might be. I have workflows for picking patches from bugzilla attachements, but no sensible way to get your contribution without more manual intervention out of the mail (clients).
Odd,. both http://gegl.org/operations.html#gegl%3Avideo-degradation and https://git.gnome.org/browse/gegl/plain/tests/compositions/reference/video-degradation.png seem to have processing happening to me.
/pippin
I've pushed these changes to git master - albeit with slightly deteriorated meta data since the diffs were manually incorporated.thank you, I'll use bugzilla next time. I assumed everybody just uses
git am.We do use git am formatted patches - but attached to bugs in bugzilla instead
(clients).The unexpected part is that the test now passes, despite not doing any
as OpenCL (which did no processing)Odd,. both http://gegl.org/operations.html#gegl%3Avideo-degradation and
https://git.gnome.org/browse/gegl/plain/tests/compositions/reference/ video-degradation.png
I investigated a bit further:
$ rm tests/compositions/output/*
$ GEGL_USE_OPENCL=no make check
/home/vesely/gegl/tests/compositions/reference/video-degradation.png and /home/vesely/gegl/tests/compositions/output/video-degradation.png are identical
PASS video-degradation.xml
SKIP video-degradation.xml (OpenCL)
$ diff /home/vesely/gegl/tests/compositions/reference/video-degradation.png /home/vesely/gegl/tests/compositions/output/video-degradation.png
Binary files /home/vesely/gegl/tests/compositions/reference/video-degradation.png and /home/vesely/gegl/tests/compositions/output/video-degradation.png differ
$ compare /home/vesely/gegl/tests/compositions/reference/video-degradation.png /home/vesely/gegl/tests/compositions/output/video-degradation.png -compose src diff-cpu.png
(see attachment)
with OpenCL (unconditionally goto error), the cpu output is the same as above, and comparing opencl output gives: /home/vesely/gegl/tests/compositions/reference/video-degradation.png and /home/vesely/gegl/tests/compositions/output/video-degradation.png are identical PASS video-degradation.xml
(lt-gegl:6636): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpload_c'.
(lt-gegl-imgcmp:6662): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpload_c'.
/home/vesely/gegl/tests/compositions/reference/video-degradation.png and /home/vesely/gegl/tests/compositions/output/opencl-video-degradation.png are identical
PASS video-degradation.xml (OpenCL)
$ diff ~/gegl/tests/compositions/output/video-degradation.png ~/gegl/tests/compositions/output/opencl-video-degradation.png
fixing the original OpenCL error produces the same output as CPU version.
am I doing something wrong?
Jan
/pippin
Jan Vesely
