Darktable plug-in in GIMP
10 of 10 messages available
Darktable plug-in in GIMP Mika Mantere 30 Apr 00:08
  Darktable plug-in in GIMP Tobias Ellinghaus 30 Apr 14:33
   Darktable plug-in in GIMP Carmelo DrRaw 30 Apr 14:51
    Darktable plug-in in GIMP Tobias Ellinghaus 30 Apr 14:58
     Darktable plug-in in GIMP Elle Stone 30 Apr 15:12
      Darktable plug-in in GIMP Tobias Ellinghaus 30 Apr 15:35
     Darktable plug-in in GIMP Carmelo DrRaw 30 Apr 15:22
      Darktable plug-in in GIMP Tobias Ellinghaus 30 Apr 15:49
   Darktable plug-in in GIMP Mika Mantere 30 Apr 18:22
    Darktable plug-in in GIMP Carmelo DrRaw 30 Apr 18:56
Mika Mantere
2016-04-30 00:08:21 UTC (almost 9 years ago)
The plug-in works great in importing NEF to GIMP, but now when I open some TIF files in GIMP, it uses the plug-in in the same fashion as if I was opening raw files in GIMP, i.e. launching darktable and upon exiting exporting the file to GIMP as 32-bit EXR. This happens with some TIF files but not with all TIF files. Is it supposed to do that?
I do remember having trouble opening some TIF files in GIMP before, I think some older TIF files with many Photoshop layers. This might actually work better through Darktable, anyway :-)
Thanks, Mika
Tobias Ellinghaus
2016-04-30 14:33:53 UTC (almost 9 years ago)
Am Freitag, 29. April 2016, 17:08:21 schrieb Mika Mantere:
No, it is not. The problem is that most raw formats are TIFF files with some extra data. For CR2 that's not a big problem, there is a way to recognize them (Canon was clever enough to have a unique magic for their files), other formats however can't be reliably distinguished from TIFFs. NEF is one of those. So right now the code wrongly assumes that your TIFF is a NEF and sends it to darktable. Until that is fixed you have to manually select the TIFF loader in the lower left hand corner of the open dialog.
Happy coincidence. Maybe you can provide a sample file to bugzilla so someone can have a look at properly supporting them in GIMP.
Thanks,
Mika
Tobias
Carmelo DrRaw
2016-04-30 14:51:05 UTC (almost 9 years ago)
This issue is easily handled by other RAW loading plug-ins by intercepting the input files with .tif or .tiff extension and running the normal GIMP loading procedure in such cases.
Here is an example from the PhotoFlow plug-in, which was originally derived from UFraw: https://github.com/aferrero2707/PhotoFlow/blob/stable/src/plugin/pfgimp-load.cc#L213
Andrea
Thanks,
Mika
Tobias_______________________________________________ gimp-developer-list mailing list
Tobias Ellinghaus
2016-04-30 14:58:32 UTC (almost 9 years ago)
Am Samstag, 30. April 2016, 16:51:05 schrieb Carmelo DrRaw:
Sure, you can work around that, but it's not a proper fix, is it? So I personally prefer to keep the behaviour broken to make someone fix it for real.
Andrea
Tobias
Elle Stone
2016-04-30 15:12:14 UTC (almost 9 years ago)
Just from curiosity, who is the "someone" who should fix loading of raw files "for real"?
Is this something that needs to be fixed in GIMP?
Or is this something that needs to be fixed by the camera manufacturers?
Elle
Carmelo DrRaw
2016-04-30 15:22:13 UTC (almost 9 years ago)
If UFraw was forced to implement this workaround already few years ago, so I guess it will still take quite some time until someone fixes that for good… meanwhile you will be flooded by comments from unhappy users because this new DT plugin code already made it into PPAs that lots of people use.
My suggestion: implement the workaround as soon as possible, and then identify the person that should implement a proper fix into GIMP and try to convince her/him to do the job.
Andrea
Tobias
[...]_______________________________________________ gimp-developer-list mailing list
Tobias Ellinghaus
2016-04-30 15:35:16 UTC (almost 9 years ago)
Am Samstag, 30. April 2016, 11:12:14 schrieb Elle Stone:
Mitch has been working on the magic part last week already, so it's currently work in progress.
Well, if we could convince camera manufacturers to fix their file formats that would be great, but 1) that won't happen and 2) GIMP still needs to recognize the billions of existing files out there.
Elle
Tobias
Tobias Ellinghaus
2016-04-30 15:49:36 UTC (almost 9 years ago)
Am Samstag, 30. April 2016, 17:22:13 schrieb Carmelo DrRaw:
I guess it's more a matter of a few weeks than months.
Sorry, no. I don't care if some people complain, that's what you get from running development versions. But just rejecting all files ending in ".tif" (and variations thereof) is wrong, there are cameras who call their raw files .tif. Old cameras, but still.
Andrea
Tobias
Mika Mantere
2016-04-30 18:22:28 UTC (almost 9 years ago)
Thanks for the info, Tobias. I wasn't aware of the close nature of TIFFs and raw files in general, it makes more sense now.
I've used Darktable and GIMP (and Inkscape) for everything since moving on to linux side and couldn't be happier for finally having a plug-in seamlessly linking the two. It was really the last missing piece from my old Photoshop/Lightroom combo.
Thanks, Mika
some
files
think
Thanks,
Mika
Tobias
Carmelo DrRaw
2016-04-30 18:56:11 UTC (almost 9 years ago)
Hi Mika!
you might want to have a look to the PhotoFlow plug-in as well, which tries to provide the same sort of Photoshop/Lightroom integration in the GIMP world. It is designed in such a way that you can re-process the original RAW file from the saved XCF by simply re-running the plug-in on the layer that was created by the initial RAW loading.
If you have access to youtube, here is a 15mn video that shows how all this works in practice: https://youtu.be/945OnK93C1g
From the RAW processing point of view, PhotoFlow is almost as feature-rich as Darktable, and has even some advantages like LMMSE demosaicing and inputs NR for high-ISO images.
Thanks, Mika
some
files
think
Thanks,
Mika
Tobias
