GIMP crashes at changing of theme
GIMP crashes at changing of theme Alexander Rabtchevich 01 Apr 04:06
  GIMP crashes at changing of theme Kevin Payne 01 Apr 05:16
   GIMP crashes at changing of theme Alexander Rabtchevich 01 Apr 17:58
   GIMP crashes at changing of theme Akkana Peck 04 Apr 00:16
    GIMP crashes at changing of theme Michael Schumacher 04 Apr 06:35
     GIMP crashes at changing of theme C R 04 Apr 07:33
2016-04-01 04:06:25 UTC (about 9 years ago)
Hello
Grey icons from small theme become undistinguishable to me - they do not have enough contrast between background and image. When I switch to other theme, GIMP crashes. Current git, builds by Otto Meier, Mint 17.3 x64.
Gdk:ERROR:/build/gtk+2.0-KsZSEA/gtk+2.0-2.24.23/gdk/gdkregion-generic.c:1114:miUnionNonO: assertion failed: (r->x1 < r->x2)
gimp: terminated: Aborted
With respect, Alexander Rabtchevich
Kevin Payne
2016-04-01 05:16:59 UTC (about 9 years ago)
Can you be more specific about which Icon Theme you are having the low contrast problem with and what your system colours are, as the Small Theme will use your system colours there is no way to know which Icon Theme is going to work best for you.
And does the crash happen when you change Theme from Small to any other Theme, or only when you change from Small to a specific Theme and when you then re-start GIMP, does it start OK with the new Theme?
Kevin
From: gimp-developer-list  on behalf of Alexander Rabtchevich
Sent: 01 April 2016 05:06
To: gimp-developer
Subject: [Gimp-developer] GIMP crashes at changing of theme
Hello
x64.
With respect,
2016-04-01 17:58:19 UTC (about 9 years ago)
Hello
I have such a problem with the small icon theme. It can be switched to the default theme. The default theme is more recognizable due its bigger size. Both themes look as gray signs over the gray background. Toolbox and icons background have the same gray color, so the icons visually select only by their signs.
Here is the screenshot of my GIMP view with the default theme.
https://yadi.sk/i/Lvtkcqgcqfh8a
Crash occurs when I switch to any of the new numbered themes: Lighter... Darker... Switching between the small and default themes is okay. When switching to the new theme, dialog becomes redrawn, but for a while, and the program crashes.
gimp_display_shell_profile_update gimp_display_shell_profile_update
[New Thread 0x7fffbddca700 (LWP 10723)] [New Thread 0x7fffbd5c9700 (LWP 10724)] [New Thread 0x7fffa679f700 (LWP 10725)] [New Thread 0x7fffa5f9e700 (LWP 10726)] [New Thread 0x7fffa579d700 (LWP 10727)] [New Thread 0x7fffa4b4a700 (LWP 10728)] [New Thread 0x7fff8ffff700 (LWP 10729)] [New Thread 0x7fff8f7fe700 (LWP 10730)] [Thread 0x7fff8f7fe700 (LWP 10730) exited] [Thread 0x7fffa679f700 (LWP 10725) exited] [Thread 0x7fffa4b4a700 (LWP 10728) exited] [Thread 0x7fffbddca700 (LWP 10723) exited] [Thread 0x7fffc498b700 (LWP 10708) exited] [Thread 0x7fff8ffff700 (LWP 10729) exited] [Thread 0x7fffbd5c9700 (LWP 10724) exited] [Thread 0x7fffa5f9e700 (LWP 10726) exited] [New Thread 0x7fffa5f9e700 (LWP 10733)] [New Thread 0x7fffbd5c9700 (LWP 10734)] [New Thread 0x7fff8ffff700 (LWP 10735)] [New Thread 0x7fffc498b700 (LWP 10736)] [New Thread 0x7fffbddca700 (LWP 10737)] [New Thread 0x7fffa7e5a700 (LWP 10738)] [New Thread 0x7fffa7659700 (LWP 10739)] **
Program received signal SIGABRT, Aborted. 0x00007ffff3210cc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56 56 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory. (gdb) thread apply all bt full
Thread 19 (Thread 0x7fffa7659700 (LWP 10739)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
#1 0x00007ffff41cdce5 in g_cond_wait_until () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#2 0x00007ffff41621c1 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#3 0x00007ffff41b1862 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#4 0x00007ffff41b0f05 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffa7659700) at pthread_create.c:312
__res =
pd = 0x7fffa7659700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736001840896, 2687345097883791521, 1, 0, 140736001841600, 140736001840896,
-2687504472841637727, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, ---Type to continue, or q to quit--- data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
__PRETTY_FUNCTION__ = "start_thread" #6 0x00007ffff32d447d in clone ()
at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111 No locals.
Thread 18 (Thread 0x7fffa7e5a700 (LWP 10738)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
---Type to continue, or q to quit--- #5 0x00007ffff35a7182 in start_thread (arg=0x7fffa7e5a700) at pthread_create.c:312
__res =
pd = 0x7fffa7e5a700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736010233600, 2687345097883791521, 1, 0, 140736010234304, 140736010233600,
-2687503372793139039, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
Thread 17 (Thread 0x7fffbddca700 (LWP 10737)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
---Type to continue, or q to quit--- #1 0x00007ffff41cdce5 in g_cond_wait_until () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffbddca700) at pthread_create.c:312
__res =
pd = 0x7fffbddca700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736378742528, 2687345097883791521, 1, 0, 140736378743232, 140736378742528,
-2687481734747901791, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
---Type to continue, or q to quit--- __PRETTY_FUNCTION__ = "start_thread" #6 0x00007ffff32d447d in clone ()
Thread 16 (Thread 0x7fffc498b700 (LWP 10736)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
#3 0x00007ffff416274b in g_async_queue_timeout_pop () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#4 0x00007ffff41b1956 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff41b0f05 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#6 0x00007ffff35a7182 in start_thread (arg=0x7fffc498b700) at pthread_create.c:312
---Type to continue, or q to quit--- __res =
pd = 0x7fffc498b700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736491730688, 2687345097883791521, 1, 18847104, 140736491731392, 140736491730688, -2687286607404322655, -2687320130784186207},
pagesize_m1 =
sp =
freesize =
__PRETTY_FUNCTION__ = "start_thread" #7 0x00007ffff32d447d in clone ()
Thread 15 (Thread 0x7fff8ffff700 (LWP 10735)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
#1 0x00007ffff41cdce5 in g_cond_wait_until () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 ---Type to continue, or q to quit--- No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fff8ffff700) at pthread_create.c:312
__res =
pd = 0x7fff8ffff700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140735609304832, 2687345097883791521, 1, 75861344, 140735609305536, 140735609304832, -2687450651532709727, -2687320130784186207},
pagesize_m1 =
sp =
freesize =
---Type to continue, or q to quit--- at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111 No locals.
Thread 14 (Thread 0x7fffbd5c9700 (LWP 10734)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffbd5c9700) at pthread_create.c:312
__res =
pd = 0x7fffbd5c9700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736370349824, 2687345097883791521, 1, 69661920, 140736370350528, ---Type to continue, or q to quit--- 140736370349824, -2687482834796400479, -2687320130784186207},
pagesize_m1 =
sp =
freesize =
Thread 13 (Thread 0x7fffa5f9e700 (LWP 10733)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
---Type to continue, or q to quit--- #4 0x00007ffff41b0f05 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffa5f9e700) at pthread_create.c:312
__res =
pd = 0x7fffa5f9e700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140735978006272, 2687345097883791521, 1, 74345824, 140735978006976, 140735978006272, -2687499079973326687, -2687320130784186207},
pagesize_m1 =
sp =
freesize =
Thread 9 (Thread 0x7fffa579d700 (LWP 10727)): #0 pthread_cond_timedwait@@GLIBC_2.3.2 () ---Type to continue, or q to quit--- at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238 No locals.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffa579d700) at pthread_create.c:312
__res =
pd = 0x7fffa579d700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140735969613568, 2687345097883791521, 1, 0, 140735969614272, 140735969613568,
-2687500180021825375, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
---Type to continue, or q to quit--- sp =
freesize =
Thread 4 (Thread 0x7fffbffff700 (LWP 10709)): #0 0x00007ffff32c712d in poll () at ../sysdeps/unix/syscall-template.S:81 No locals.
#1 0x00007ffff418bfe4 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#2 0x00007ffff418c0ec in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#3 0x00007ffff418c129 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffbffff700) at pthread_create.c:312
__res =
pd = 0x7fffbffff700
---Type to continue, or q to quit--- now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736414611200, 2687345097883791521, 1, 0, 140736414611904, 140736414611200,
-2687485835904798559, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
Thread 2 (Thread 0x7fffe840e700 (LWP 10705)): #0 0x00007ffff32c712d in poll () at ../sysdeps/unix/syscall-template.S:81 No locals.
#2 0x00007ffff418c30a in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
---Type to continue, or q to quit--- #3 0x00007ffff4992336 in ?? () from /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0 No symbol table info available.
#5 0x00007ffff35a7182 in start_thread (arg=0x7fffe840e700) at pthread_create.c:312
__res =
pd = 0x7fffe840e700
now =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140737089955584, 2687345097883791521, 1, 0, 140737089956288, 140737089955584,
-2687366253814730591, -2687320130784186207}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call =
pagesize_m1 =
sp =
freesize =
---Type to continue, or q to quit--- Thread 1 (Thread 0x7ffff7fb0a40 (LWP 10701)): #0 0x00007ffff3210cc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56 resultvar = 0
pid = 10701
selftid = 10701
#1 0x00007ffff32140d8 in __GI_abort () at abort.c:89 save_stage = 2
act = {__sigaction_handler = {sa_handler = 0x7ffff72e0110, sa_sigaction = 0x7ffff72e0110}, sa_mask = {__val = {13, 140737291527072, 140737351947607, 140733193388037, 0, 4294967296, 140737272220968, 68337296, 140737291527072, 124, 140737351976213, 0, 248, 0, 0, 140737276118880}}, sa_flags = 49344, sa_restorer = 0x9} sigs = {__val = {32, 0 }}
#2 0x00007ffff41b0165 in g_assertion_message () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#3 0x00007ffff41b01fa in g_assertion_message_expr () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#4 0x00007ffff7299ae9 in ?? ()
from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 ---Type to continue, or q to quit--- No symbol table info available.
#5 0x00007ffff729acdb in ?? ()
from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 No symbol table info available.
#6 0x00007ffff729b447 in gdk_region_union () from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 No symbol table info available.
#7 0x00007ffff729b577 in gdk_region_union_with_rect () from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 No symbol table info available.
#8 0x00007ffff775d630 in gtk_widget_size_allocate () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#9 0x00007ffff762eb3a in ?? ()
#10 0x00007ffff445e210 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#11 0x00007ffff445b55f in ?? ()
#12 0x00007ffff4474088 in g_signal_emit_valist () ---Type to continue, or q to quit--- from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#13 0x00007ffff4474ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#14 0x00007ffff775d50a in gtk_widget_size_allocate () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#15 0x00007ffff7655271 in ?? ()
#16 0x00007ffff445e210 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#17 0x00007ffff445b55f in ?? ()
#18 0x00007ffff4474088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#19 0x00007ffff4474ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
---Type to continue, or q to quit--- #20 0x00007ffff775d50a in gtk_widget_size_allocate () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#21 0x00007ffff759f0f8 in ?? ()
#22 0x00007ffff445e210 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#23 0x00007ffff445b55f in ?? ()
#24 0x00007ffff4474088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#25 0x00007ffff4474ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#26 0x00007ffff775d50a in gtk_widget_size_allocate () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#27 0x00007ffff7766eaa in ?? ()
from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 ---Type to continue, or q to quit--- No symbol table info available.
#28 0x00007ffff445e210 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#29 0x00007ffff445b5e7 in ?? ()
#30 0x00007ffff4474088 in g_signal_emit_valist () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#31 0x00007ffff4474ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#32 0x00007ffff775d50a in gtk_widget_size_allocate () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 No symbol table info available.
#33 0x00007ffff7768148 in ?? ()
#34 0x00007ffff445b5e7 in ?? ()
#35 0x00007ffff4474088 in g_signal_emit_valist () ---Type to continue, or q to quit--- from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#36 0x00007ffff4474ce2 in g_signal_emit () from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 No symbol table info available.
#37 0x00007ffff75d0e20 in ?? ()
#38 0x00007ffff7286ce7 in ?? ()
#39 0x00007ffff418bce5 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#40 0x00007ffff418c048 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#41 0x00007ffff418c30a in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 No symbol table info available.
#42 0x000000000048d965 in app_run () No symbol table info available.
#43 0x000000000048d338 in main ()
Kevin
With respect,
Akkana Peck
2016-04-04 00:16:49 UTC (about 9 years ago)
Alexander Rabtchevich writes:
Kevin Payne writes:
I have that problem with the Symbolic icons with all the Light or Lighter themes. When I first switched my initial reaction was "Why are all the Toolbox icons greyed out?!" Once I realized they weren't greyed out, they looked like that all the time, I tried to work with them, but I found that I really couldn't see the differences and had to hover over each icon to wait for the tooltip. Fortunately there are the Color and Legacy icon theme options.
The Dark themes seem to have much more contrast, with Symbolic icons, than any of the Light themes. I think the dark themes would be usable, but they don't go well with the rest of my desktop.
Another question about theme switching: every time I switch themes, my toolbox resizes to four icons across, so small that tooltips has to show a horizontal scrollbar for most tools. It has to be six icons across to avoid a scrollbar, and I always have to resize it larger after switching themes. Is this intentional, or should I file it as a bug?
...Akkana
2016-04-04 06:35:17 UTC (about 9 years ago)
not
Kevin Payne writes:
That's why there is the Symbolic-Inverted icon theme. Its icons are created by inverting the Symbolic ones (the reason why current GIMP builds take so long) and contrast quite well with the light themes.
You can shrink the toolbox down even further by switching the various icon themes. I'd say that none of the switching should change any window sizes.
C R
2016-04-04 07:33:05 UTC (about 9 years ago)
I too had to change the light theme icons right away for lack of visibility. Maybe the "symbolic inverted" icon theme should be the default active. Then only the mid-tone theme(s) have visibility issues. :)
My 2p. -C
not
Kevin Payne writes:
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
