gegl builds fail
gegl builds fail richard brown 23 Mar 12:41
richard brown
2016-03-23 12:41:10 UTC (about 9 years ago)
gegl builds fail
On 21/03/16 22:17, Øyvind Kolås wrote:
On Mon, Mar 21, 2016 at 3:49 PM, richard brown wrote:
I've been running gimp 2.9 in my home directory for some time now. Recently
however, gegl 0.3.2, 0.3.4 and 0.3.6 have all failed to build, I have current git pulls of glib, babl, gexiv2, harfbuzz. gegl 0.3.0 does build,
however. The current git pull of gegl fails with:
CC ff_save_la-ff-save.lo ff-save.c: In function 'write_audio_frame': ff-save.c:429:34: error: 'AV_CODEC_CAP_VARIABLE_FRAME_SIZE' undeclared (first use in this function)
if (!(c->codec->capabilities & AV_CODEC_CAP_VARIABLE_FRAME_SIZE)) ^ ff-save.c:429:34: note: each undeclared identifier is reported only once for
each function it appears in
ff-save.c: In function 'write_video_frame': ff-save.c:824:40: error: 'AV_CODEC_CAP_INTRA_ONLY' undeclared (first use in
this function)
if (c->codec->capabilities & AV_CODEC_CAP_INTRA_ONLY)
Which version of ffmpeg / libavformat do you have installed? This should be reported by $ pkg-config --modversion libavformat # on my system it reports 57.28.100 and GEGL is rigged up to not try building with older than 55.48.100 - maybe this needs to be bumped to avoid trying to build with an as old version of libavformat as you have.
libavformat version is 56.36.100
A
possible workaround is passing --without-libavformat to autogen/configure to skip building the ffmpeg based ops (which aren't used by GIMP anyway).
/pippin
-which worked! Thank-you. Gimp has built too.
