gegl builds fail
gegl builds fail richard brown 21 Mar 14:49
  gegl builds fail Øyvind Kolås 21 Mar 22:17
richard brown
2016-03-21 14:49:25 UTC (about 9 years ago)
gegl builds fail
I've been running gimp 2.9 in my home directory for some time now. Recently however, gegl 0.3.2, 0.3.4 and 0.3.6 have all failed to build, I have current git pulls of glib, babl, gexiv2, harfbuzz. gegl 0.3.0 does build, however. The current git pull of gegl fails with:
CC ff_save_la-ff-save.lo ff-save.c: In function 'write_audio_frame': ff-save.c:429:34: error: 'AV_CODEC_CAP_VARIABLE_FRAME_SIZE' undeclared (first use in this function)
if (!(c->codec->capabilities & AV_CODEC_CAP_VARIABLE_FRAME_SIZE)) ^ ff-save.c:429:34: note: each undeclared identifier is reported only once for each function it appears in
ff-save.c: In function 'write_video_frame': ff-save.c:824:40: error: 'AV_CODEC_CAP_INTRA_ONLY' undeclared (first use in this function)
if (c->codec->capabilities & AV_CODEC_CAP_INTRA_ONLY) ^ Makefile:1169: recipe for target 'ff_save_la-ff-save.lo' failed make[4]: *** [ff_save_la-ff-save.lo] Error 1 make[4]: *** Waiting for unfinished jobs.... make[4]: Leaving directory
'/home/richard/Software/gimp-git/gegl/operations/external' Makefile:937: recipe for target 'all' failed make[3]: *** [all] Error 2
make[3]: Leaving directory
'/home/richard/Software/gimp-git/gegl/operations/external' Makefile:504: recipe for target 'all-recursive' failed make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory '/home/richard/Software/gimp-git/gegl/operations' Makefile:627: recipe for target 'all-recursive' failed make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory '/home/richard/Software/gimp-git/gegl' Makefile:533: recipe for target 'all' failed make: *** [all] Error
All the builds that fail, fail around ff_save.c. I'm a bit stumped, and can't find much on google. I've upgraded make from 3.8 to 4.1. Because gegl-0.3.6 won't build, neither will gimp-2.9. Quite possible I've done something silly, but, thoughts anyone?
Øyvind Kolås
2016-03-21 22:17:42 UTC (about 9 years ago)
gegl builds fail
Which version of ffmpeg / libavformat do you have installed? This should be reported by $ pkg-config --modversion libavformat # on my system it reports 57.28.100 and GEGL is rigged up to not try building with older than 55.48.100 - maybe this needs to be bumped to avoid trying to build with an as old version of libavformat as you have. A possible workaround is passing --without-libavformat to autogen/configure to skip building the ffmpeg based ops (which aren't used by GIMP anyway).
/pippin
