Border artifact from using nohalo to scale a layer with an alpha channel
Elle Stone
2016-02-22 23:12:37 UTC (about 9 years ago)
The following three bugs are closed, but there still seems to be a related? new? bug with nohalo scaling (and probably lohalo, but not with cubic or linear):
https://bugzilla.gnome.org/show_bug.cgi?id=634901 Bug 634901 - Resizing an image with alphachannel creates 1 pixel border down and right
https://bugzilla.gnome.org/show_bug.cgi?id=698601 Bug 698601 - scaling up without alpha adds several-pixel gradient border
https://bugzilla.gnome.org/show_bug.cgi?id=734378 Bug 734378 - Image manipulation (scale,rotate) may cause vertical image artefacts
Scaling up or down using nohalo produces a partially transparent border around the layer if the layer has an alpha channel. This is a long-standing issue that still obtains (at least scaling down has produced the edge artifact for a long time, bug 698601 describes the opposite situtation for scaling up).
I only just discovered that removing the alpha channel at least sometimes allows to scale a layer without creating the edge artifacts. So I'm not sure if removing the alpha channel always allows to scale without creating edge artifacts.
This bug was confirmed using babl/GEGL/GIMP updated today.
Should I file a new bug report? or maybe instead open one of the old bug reports?
Elle
Øyvind Kolås
2016-02-23 12:45:03 UTC (about 9 years ago)
In general it is better to open new bug-reports, rather than re-open old ones seeming similar - long threads of possibly different problems discussed in comments makes it hard to follow progress of an issue. This issue seems like it might already have a bug though bug #698468.
/pippin
Elle
Elle Stone
2016-02-24 22:37:44 UTC (about 9 years ago)
/pippin
Pippin, thanks! I completely forgot to ask the main question, which was whether to post a GIMP or a GEGL bug report.
Elle
Elle
Jehan Pagès
2016-02-25 17:39:28 UTC (about 9 years ago)
/pippin
Well it depends simply if you know (or think in case you don't know) if this is a bug on GIMP or GEGL. If the project settings was a mistake, developers can always re-qualify bug owners anyway. So that's not a problem. :-)
Jehan
Elle
scaling up).
artifacts.
Elle
