Segmentation Fault at initial run
Segmentation Fault at initial run Kerem Kat 20 Mar 20:22
Segmentation Fault at initial run Øyvind Kolås 20 Mar 20:34
Segmentation Fault at initial run Øyvind Kolås 21 Mar 01:59
Kerem Kat
2007-03-20 20:22:31 UTC (almost 18 years ago)
Hi, I checked out babl and gegl from svn and compiled them on fedora 6 with autogen.sh , but without success to run.
gegl: rev. 1436 babl: rev. 230
When I run the gegl binary, it gives the following:
WARNING **: Failed to set operation type for nop, using a passthrough op instead
Segmentation fault
When I google on this, I have found that my problem is same as the mentioned gegl-0.0.4 seg fault problem in Jan 2007.
I tried make install as root, make install in operations as suggested there but it those does not help in this case.
Any other suggestions?
Øyvind Kolås
2007-03-20 20:34:13 UTC (almost 18 years ago)
This mean that GEGL has failed to find any of it's plug-ins, you probably want trying to set the environment variable GEGL_PATH to point to the location where the .so's of the operations ended up being installed and make another attempt.
/Øyvind K.
Øyvind Kolås
2007-03-21 01:59:48 UTC (almost 18 years ago)
It seems like I responded a bit prematurely, there has been changes recently to make GEGL and babl work on win32, these seems to have broken the build on Unixes right now. I do not have the immediate time available to look into these issues right now, unfortunately this leaves us with broken trunk revisions, the changes to make it work again shouldn't be very large though.
/Øyvind K.
