A better way to close a path where an end node is on top of a start node
15 of 17 messages available
A better way to close a path where an end node is on top of a start node ugajin 29 Jan 13:53
  1454156634061.710746341@boxbe 31 Jan 16:54
   A better way to close a path where an end nodeis on top of a start node Joseph Bupe 31 Jan 08:08
    A better way to close a path where an end nodeis on top of a start node Ofnuts 31 Jan 23:04
     1454285312006.960626117@boxbe 05 Feb 18:07
      A better way to close a path where an endnodeis on top of a start node Joseph Bupe 01 Feb 06:29
       A better way to close a path where an endnodeis on top of a start node Burnell West 05 Feb 18:57
     A better way to close a path where an end nodeis on top of a start node Gez 31 Jan 23:58
  A better way to close a path where an end node is on top of a start node Sven Claussner 30 Jan 12:04
  A better way to close a path where an end node is on top of a start node Ofnuts 31 Jan 23:14
   A better way to close a path where an end node is on top of a start node Simon Budig 31 Jan 23:27
    A better way to close a path where an end node is on top of a start node ugajin@talktalk.net 01 Feb 10:55
     A better way to close a path where an end node is on top of a start node Simon Budig 01 Feb 11:17
      A better way to close a path where an end node is on top of a start node Simon Budig 01 Feb 11:23
       A better way to close a path where an end node is on top of a start node Ofnuts 01 Feb 22:26
      A better way to close a path where an end node is on top of a start node ugajin@talktalk.net 02 Feb 09:48
   A better way to close a path where an end node is on top of a start node ugajin@talktalk.net 01 Feb 10:54
ugajin
2016-01-29 13:53:06 UTC (about 9 years ago)
I have been searching for how best to close a path where an end node is on top of a start node.
One work-around is to not place the end node on the start node, so that the path can be closed in the usual way, and then move what had been intended to be the end node on top of the start node. This hack will create a path segment between the start end and nodes with the expected zero values, but it will be a closed path.
Not closing path nodes may not always create an issue when using paths to generate bitmapped images, but it may when e.g. stroking paths, and the otherwise unnecessary data can be a tad messy when exporting paths.
Another workaround (good for OCD types) is perhaps to place the end node on the start node, export and edit the path data adding a close-path flag, and then import it back into Gimp.
Perhaps there is a better way?
Sven Claussner
2016-01-30 12:04:15 UTC (about 9 years ago)
what exactly are you trying to achieve with this method? I also think this is rather a question for the gimp-user list than the developer list.
Greetings
Joseph Bupe
2016-01-31 08:08:01 UTC (about 9 years ago)
Is there a reason why the path can close by just clicking the last node onto the first node? Why do we have to CTRL or Command + Click ?
On 30 January 2016 at 14:04, Sven Claussner wrote:
[image: Boxbe] This message is eligible for Automatic Cleanup! (scl.gplus@gmail.com) Add cleanup rule
| More info
Greetings
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
D/Insp. BUPE Joseph
*Data Protection Officer, INTERPOL NCB Lusaka*
*Zambia Police Service Headquarters,*
*Criminal Investigation Department,**P.O. Box 50104, Lusaka*
*Zambia*
*Officer Phone/Fax*: + 260 211 255218
2016-01-31 23:04:18 UTC (about 9 years ago)
Because clicking on a node is selecting it, and this i something you'll want to do if you want to extend the path from the other end. In other words, you create a path with M, N, O, P, Q and then you want to add points L, K, J, so after adding Q you'll click on M, and you don't want this to close the stroke.
2016-01-31 23:14:31 UTC (about 9 years ago)
If you are doing this in a script:
* copy the backwards tangent of the last node to the first node * drop the last node and its tangent handles * mark the stroke closed
Simon Budig
2016-01-31 23:27:01 UTC (about 9 years ago)
or use gimp_vectors_stroke_close.
Bye, Simon
simon@budig.de              http://simon.budig.de/
Gez
2016-01-31 23:58:17 UTC (about 9 years ago)
Double clicking on the first node could work too. But that in that case selecting the first node with a single click should revert the behavior, allowing to close the path double clicking the final node of the other end of the path.
G.
Joseph Bupe
2016-02-01 06:29:43 UTC (about 9 years ago)
G.
Sounds reasonable. Double clicking the final node should close the path. It's more discoverable than than using CTRL + Click.
ugajin@talktalk.net
2016-02-01 10:54:53 UTC (about 9 years ago)
Ofnuts - I shall need more help with doing this using a script.
----Original Message----
Date: 31/01/2016 23:14
To:
Subj: Re: [Gimp-user] A better way to close a path where an end node
node on the start node, export and edit the path data adding a close- path flag, and then import it back into Gimp.
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
List archives: https://mail.gnome.org/archives/gimp-user-list
ugajin@talktalk.net
2016-02-01 10:55:01 UTC (about 9 years ago)
Simon - I don't see how this will work in the scenario described.
Date: 31/01/2016 23:27
To:
Bye, Simon
simon@budig.de http://simon.budig.de/ _______________________________________________ gimp-user-list mailing list
Simon Budig
2016-02-01 11:17:53 UTC (about 9 years ago)
We're talking about programmatically constructing a stroke within a vectors object, that has its end node placed on the start node and then is supposed to be closed. right?
I started a new gimp instance and issued the following commands in the script fu console:
(gimp-image-list)
(1 #(1))
(gimp-vectors-new 1 "testpath")
(3)
(gimp-image-insert-vectors 1 3 0 0)
(#t)
(gimp-vectors-bezier-stroke-new-moveto 3 100 100)
(1)
(gimp-vectors-bezier-stroke-cubicto 3 1 150 100 200 150 200 200)
(#t)
(gimp-vectors-bezier-stroke-cubicto 3 1 150 200 100 150 100 100)
(#t)
(gimp-vectors-stroke-get-points 3 1)
(0 18 #(100.0 100.0 100.0 100.0 150.0 100.0 200.0 150.0 200.0 200.0 150.0 200.0 100.0 150.0 100.0 100.0 100.0 100.0) 0)
(gimp-vectors-stroke-close 3 1)
(#t)
(0 12 #(100.0 150.0 100.0 100.0 150.0 100.0 200.0 150.0 200.0 200.0 150.0 200.0) 1)
This is constructing a path with two bezier segments, where the end of the last segment coincides with the start of the first segment.
As you can see gimp-vectors-stroke-close reduced the number of points: Gimp has determined, that the first and the last control point are on top each other and that their respective control handles do not hold relevant information (since their coordinates are identical with the anchor handle).
So the final result after the stroke-close contains exactly six handles (i.e. the coordinate array contains 12 elements). Which IMHO is the desired result.
I hope this helps, Simon
Simon Budig
2016-02-01 11:23:05 UTC (about 9 years ago)
Sorry, I forgot to add that I tested this with a version where I have changed how moveto/cubicto/closepath work, i.e. for you the order of the coordinates might be different (and I promptly discovered a bug in my changes).
But the closepath-optimization is in the older gimp versions available as well and should work the same for you.
Bye, Simon
2016-02-01 22:26:51 UTC (about 9 years ago)
Yes it does. Good to know.
ugajin@talktalk.net
2016-02-02 09:48:17 UTC (about 9 years ago)
In a sense it may.
Thanks.
Date: 01/02/2016 11:17
To:
then
(gimp-image-list)
(1 #(1))
(3)
(#t)
(1)
(#t)
(#t)
(#t)
handles
Burnell West
2016-02-05 18:57:44 UTC (about 9 years ago)
I think part of the complication on this arises from the behavior of the free select “lasso”, particularly when add-to-selection is active. It’s much like path creation in this mode.
I also think the double-click termination is reasonable.
G.
Sounds reasonable. Double clicking the final node should close the path. It's more discoverable than than using CTRL + Click. _______________________________________________ gimp-developer-list mailing list
