Registry followup
This discussion is connected to the gimp-web-list.gnome.org mailing list which is provided by the GIMP developers and not related to gimpusers.com.
Registry followup Ingo Lütkebohle 10 Jan 14:06
Ingo Lütkebohle
2016-01-10 14:06:53 UTC (over 9 years ago)
Registry followup
On Alexander's suggrstion, I put a notice on the registry site that a solution will take some more time.
In this regard, I have one idea: Re-use software from the ROS community. Check out
http://rosindex.github.io
In contrast to the registry, that site is completely static, and is generated automatically. It is generated from metadata (a simple xml file) that the packages authors add to their source code repositories. The format is described at
http://www.ros.org/reps/rep-0127.html
Let me know if you'd interested in that option. As you may know, my main field of work is robotics, so I know that stuff well.
Cheers, Ingo
