Support for seam carving
Support for seam carving Ashijeet Acharya 07 Jan 04:43
  Support for seam carving Alexandre Prokoudine 08 Jan 22:15
Ashijeet Acharya
2016-01-07 04:43:15 UTC (over 9 years ago)
Hi all ,
Is there any support related to seam carving technique in GIMP.
If not I would like to add functionality related to this matter in the upcoming versions of GIMP.
Thanks Ashijeet
2016-01-08 22:15:07 UTC (over 9 years ago)
On Thu, Jan 7, 2016 at 7:43 AM, Ashijeet Acharya wrote:
Hi all ,
Same answer as the one I gave you in December :)
You might want to take this into consideration:
http://liquidrescale.wikidot.com/
http://blog.mmiworks.net/2012/05/teaching-interaction-12.html
Alex
