gimp-docs-list Digest, Vol 41, Issue 9
1 of 2 messages available
mailman.11.1450008005.27754... 13 Dec 17:24
  gimp-docs-list Digest, Vol 41, Issue 9 James Bush 13 Dec 17:24
James Bush
2015-12-13 17:24:28 UTC (over 9 years ago)
Drop this topic; how pointless.
Sent from Outlook Mobile
On Sun, Dec 13, 2015 at 4:01 AM -0800, wrote:
Send gimp-docs-list mailing list submissions to gimp-docs-list@gnome.org
To subscribe or unsubscribe via the World Wide Web, visit https://mail.gnome.org/mailman/listinfo/gimp-docs-list or, via email, send a message with subject or body 'help' to gimp-docs-list-request@gnome.org
You can reach the person managing the list at gimp-docs-list-owner@gnome.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of gimp-docs-list digest..."
Today's Topics:
1. Re: 'make pdf' fails (Kolbj?rn Stuest?l)
Message: 1 Date: Sat, 12 Dec 2015 21:59:12 +0100 From: Kolbj?rn Stuest?l
To: gimp-docs-list@gnome.org
Subject: Re: [Gimp-docs] 'make pdf' fails Message-ID:
Content-Type: text/plain; charset=windows-1252; format=flowed
I was a bit curious inspired by this discussion, and tried to make a pdf file. Near the same result as Julien got:
Build gimp.pdf built-in module xetex registered no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for ucs
no support found for inputenc
no support found for fancybox
built-in module makeidx registered no support found for babel
no support found for cmap
no support found for db2latex
built-in module bibtopic registered building additional files...
checking if compiling is necessary... the output file doesn't exist
xelatex -interaction=batchmode gimp.tex Unexpected error occured
Error: [Errno 2] No such file or directory Makefile:1492: recipe for target 'pdf/nn/gimp.pdf' failed make: *** [pdf/nn/gimp.pdf] Error 1
I am running this using CygWin 64 on Windows 7 Home. All the modules not found are installed. "make validate-nn" returns no errors. Making HTML files works as expected. To be on the safe side I also run autogen.sh with parameters. No errors. I tried both "make pdf" and "make pdf-nn". Same result.
I have no plans building pdf files for this help, so there is no reason using time to fix this. As said, I am just curious. If needed, I think I am able to make pdf files from the HTML files. Mostly I write this to tell that there at least is one more having problems with the "make pdf" command.
Kolbj?rn
Den 11.12.2015 21:19, Julien Hardelin skreiv:
"So it seems that all you have to do is to install the proper package from your distribution (e.g. texlive-lang-french or babel-french)"
Unfortunately no. texlive-lang-french has been installed from a long tme and babel-french is unknown in my system.
Julien _______________________________________________ gimp-docs-list mailing list
Subject: Digest Footer
End of gimp-docs-list Digest, Vol 41, Issue 9
