Bug found: Unified transform and perspective tool fail silently when layer is hidden.
C R
2015-12-08 17:28:23 UTC (almost 10 years ago)
In 2.8 it was possible to hide the layer you are transforming (with perspective tool) to get the original out of the way during transform.
In 2.9 you can still hide the layer after transform has begun, but the transform will fail unless the layer is unhidden before applying the transform (it fails silently).
Steps to reproduce: 1. Make selection with rectangle (or other) selection tool. 2. Switch to Unified Transform Tool (or Perspective tool, which fails in the same way)
3. Click to begin transform, then hide the layer (removes untransformed original so you can see what you are doing). 4. Move control corners to perspective transform the layer as you would normally.
5. Hit the Enter key or otherwise apply the transformation.
The transformation fails silently, and you must begin again.
The only solution is to remember to un-hide the layer before applying the transformation.
Proposed solutions: A. Make the original hide automatically, making it unnecessary to hide the layer during transform.
B. Make sure the transformation is applied, regardless of the hidden state of the layer.
I have also posted this information here:
https://bugzilla.gnome.org/show_bug.cgi?id=759194
-C
Gez
2015-12-09 06:05:31 UTC (almost 10 years ago)
Proposed solutions:
I raised this subject in the UI mailing list a few days ago. In my opinion, A should be the solution.
B, applying a transform on a hidden layer, could be problematic. It's not a good idea to touch layers that are hidden, so preventing any tool from working on hidden layers is probably a good thing and all tools should be consistent doing so.
We need to discuss the usefulness of having the original layer during transforms. In my experience, most of the times it's a hurdle, blocking the context for the transform.
But I'm aware that in some cases users would need to compare the transformed layer vs. the original.
I don't think it's a good idea to rule out that situation, but I'm convinced that it's an exception, and more frequently users want the original layer hidden.
Does anyone have a different opinion on this one? I'm interested to know alternative workflows where that option is more useful than hiding the original layer.
Gez.
C R
2015-12-09 07:30:08 UTC (almost 10 years ago)
One solution that involves keeping the original untransformed are: add checkbox "show original" in the transform tool menu. I still recommend that is is turned off by default, along with the "grid", which also gets in the way of seeing the transform.
What I mainly use the perspective transform tool for is applying a screen graphic to a powered-off device to make it look like it's turned on, so I need to see what is behind it. I also perform minor perspective adjustments to objects in photo collages to make them look like they were sitting next to eachother. I have never found keeping the original there to be useful in any way, which is why I suggest it be hidden by default. I also suggest (while I'm suggesting things ;P), that the transparency of the transformation preview be taken down to 75% opacity by default (though keeping in changeable is good). This provides an even greater visibility to what's underneath, so you can ensure you are not covering up essential elements of what is underneath.
tldr: For me, context visibility is everything with the transform tool. I always transform in relation to other layers, or the border of the image, never in relation to the original, so I definitely agree with Gez on that.
-C
-C
Gez.
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
Elle Stone
2015-12-09 13:01:27 UTC (almost 10 years ago)
Is this what you mean by "original layer"? If a layer stack has two layers, A and B, with B as the upper layer, and if a transform/rotate/etc tool is used on B, the "original layer" is layer B *before* the tranform, and the transformed layer is what B would look like if the transform were made using the current settings.
If I understand what you mean by "original layer", I don't need to see the original layer B. What I really do need to see is layer A, meaning I'd like the option to set the opacity of the transformed layer B to 50% so I can compare the transformed layer B to layer A.
Unfortunately right now lowering the opacity of layer B on which the transform is being done doesn't seem to allow to see layer A through the *transformed* layer B.
Elle
C R
2015-12-09 17:33:34 UTC (almost 10 years ago)
Yes, Elle, I think you got it. :)
You can currently kinda get around this by setting the "Image opacity" in the Tool options palate for unified transform tool to less than 100%. Unfortunately, unless you also change the "Opacity" field in the layer palate, the untransformed layer B is still in the way.
Thus my proposal:
hide/remove the untransformed version of layer B while the user is transforming it, and set the default "Image opacity" for the transform tool to 50% by default.
This would get layer B out of the way, and let you see translucently a bit of what is under the transformation preview as well (layer A).
-C
Elle
Elle Stone
2015-12-09 20:25:38 UTC (almost 10 years ago)
settings.
Thanks! for the tip.
Thus my proposal:
Your proposal sounds good to me. I have found the "untransformed" copy of the layer being transformed to be an absolute nuisance since the first time I tried to use a transform tool.
Reading Gez's post the gimp-gui-list (https://mail.gnome.org/archives/gimp-gui-list/2015-November/msg00049.html), that's also the same proposal?
Elle
C R
2015-12-10 23:40:24 UTC (almost 10 years ago)
Glad to help! I've been reading through your awesome writeups on GIMP's color systems.
Love the "Sad little colorspace" part. Poor HSV! ;)
Thus my proposal:
Most of us seem to agree on this. The only person I've ever seen that spoke up for the current way it's handled is GNUTux, on GIMPchat. But the reasoning behind it (seeing a transform in relation to the original) I've never heard of any use case where that was an actual benefit. It's always a pain in the rump. It's just something I've learned to live with, but I'd be dancing if it went away. It regularly wastes loads of time, every single time.
Yes. Hehehe. You can see what career graphic designers think of the implementation. It really, really needs to change, and if I had the coding skills, I'd have done it long ago, even if it were just patching my own version. I hate it that much! ;P
-C
Joseph Bupe
2015-12-11 08:40:05 UTC (almost 10 years ago)
Bug found: Unified transform and perspectivetool fail silently when layer is hidden.
I agree with the general feeling here.
Also, the "you can drop dockable dialogs here" text should be done with. It's not the only place one can put the dockable dialogs.
Cheer.
