GEGL-0.3.2
GEGL-0.3.2 Øyvind Kolås 21 Nov 23:59
Øyvind Kolås
2015-11-21 23:59:42 UTC (over 9 years ago)
GEGL-0.3.2
GEGL (Generic Graphics Library) is a graph based image processing framework.
GEGL provides a graph based API and framework to do demand driven, cached, non destructive image editing of sparse storage of larger than RAM images - using CPU or GPU processing. Through babl it provides support for a wide, and extendable, range of color models and pixel storage formats for input and output.
To build gegl-0.3.2 you will also need babl-0.1.14 and a recent version of glib, follow see the output of the configure script for details and optional dependencies.
Changes in this release:
• Operations: • new operations: libraw based raw loading op, tiff-save and tif-load, maze, sepia
• ff-load and ff-save revived, with support from thegrid.io • apply-lens uses less memory, higher precision computation. • disable automatic threading on many ops where it fails • force more operations to prefer operating on linear RGB data for more accurate/physical processing.
• Buffer:
• implement abyss paremeter on gegl_buffer_copy and gegl_buffer_blit • Added start of a microraptor gui based image viewer/non destructive editor. • Optimizations to scaled blitting (speeds up most GEGL UIs a bit)
This release brought to you through contribution from:
Alexandre Prokoudine, André Tupinambá, Claude Paroz, Daniel Mustieles, Debarshi Ray, Dimitris Spingos, Elle Stone, Jehan, Jordi Mas, Marco Ciampa, Martin Blanchard, Martin Srebotnjak, Massimo Valentini, Michael Henning, Michael Natterer, Necdet Yücel, Pedro Albuquerque, Piotr Drąg, Roman Lebedev, Sven Neumann, Thomas Manni, Vilson Vieira, akash akya and Øyvind Kolås.
Where to get GEGL:
The latest versions of GEGL and it's hard dependencies babl and glib can be fetched from:
http://download.gimp.org/pub/babl/0.1/babl-0.1.14.tar.bz2 http://download.gimp.org/pub/gegl/0.3/gegl-0.3.2.tar.bz2
SHA-1 sums of the released tarballs:
1e1e27a9a07da95e905d07816701b2efaf5611af babl-0.1.14.tar.bz2 c308b9994f9649bfbdf1bb63db6fbe0ba19632bd gegl-0.3.2.tar.bz2
Where to get more information about GEGL
More information about GEGL can be found at the GEGL website, http://gegl.org/ or by joining #gegl and #gimp on the IRC network GIMPnet.
Enjoy the goats /pippin
