Hotkeys Bug
Hotkeys Bug SL SL 19 Nov 11:58
  Hotkeys Bug Alexandre Prokoudine 20 Nov 18:46
SL SL
2015-11-19 11:58:17 UTC (over 9 years ago)
Hotkeys Bug
Hello, sorry for write on this e-mail (not bugzilla). In russian version hotkeys are not working by default. Even I check mark ("Use dynamic keyboard shortcuts" and "Save keyboard shortcuts on exit") hotkeys doesnt work with Shift+Z/Ctrl+V, but if i change language to russian (keyboard layout) and reassign appropriate buttons, then hotkeys are working well (for example: Shift+/Ctrl+). Thanks.
2015-11-20 18:46:14 UTC (over 9 years ago)
Hotkeys Bug
20 нояб. 2015 г. 21:38 пользователь "SL SL" написал:
Yes, they don't work on Windows. It's a known issue that isn't likely to be fixed, because noone really cares about GTK+2 anymore.
Alex
