Brush + Paint Dynamic - performance problems and comparison between 2.9 and 2.8.14.
Americo Gobbo
2015-09-05 00:45:50 UTC (over 9 years ago)
Hi all,
I've noted yesterday that something is changed on the behaviour of brushes with GIMP 2.9 - last git master commit 0593eaa. The brush stroke with a paint dynamic or not the stroke it is delaying in heavy way. I've made two videos to make a comparison with same conditions - same brush and paint dynamics.
My box is ubuntu gnome 14.04.2 - 64-bit. Memory 8Gb, Intel® Core™ i5-3570K CPU @ 3.40GHz × 4, Gallium 0.4 on AMD CAICOS.
The short video with GIMP 2.8
https://youtu.be/hP7qH02Ohhw
The short video with GIMP 2.9 https://youtu.be/_a4kchvSAvw
--- Thanks
americo
Americo Gobbo
2015-09-05 00:55:42 UTC (over 9 years ago)
Problems with the video... now is OK, see the new: https://youtu.be/3hEzQO5mp_g
Sorry ;-)
Michael Henning
2015-09-05 17:55:28 UTC (over 9 years ago)
Does this issue clear up if you disable the rulers (by unchecking View -> Show Rulers)? If so, it's probably my fault.
From, drawoc
Sorry ;-) _______________________________________________ gimp-developer-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
Americo Gobbo
2015-09-05 18:30:58 UTC (over 9 years ago)
Yes, without rulers works fine!
Americo Gobbo
2015-09-06 17:16:26 UTC (over 9 years ago)
Michael is necessary write a bug report? Thanks
Richard
2015-09-06 18:04:46 UTC (over 9 years ago)
IIRC, this was previously discussed on the mailing list (and bugzilla) and the cairo library was identified as a culprit/accessory to the lag -- as some users reported downgrading to a previous libcairo fixes the ruler lag.
However, it also appears to have been properly fixed as of mid-August: https://bugzilla.gnome.org/show_bug.cgi?id=736411#c39
Date: Sun, 6 Sep 2015 14:16:26 -0300 To: drawoc@darkrefraction.com
CC: gimp-developer-list@gnome.org
Subject: Re: [Gimp-developer] Brush + Paint Dynamic - performance problems and comparison between 2.9 and 2.8.14.
Americo Gobbo
2015-09-06 19:00:35 UTC (over 9 years ago)
Thanks Richard, but it seems all OK are to windows... on my linux box the problem is resolved only without rulers.
I work only on linux, and in this box I've two GIMP, the stable 2.8.14 (otto ppa) and and the 2.9 devel (last git master). My box is ubuntu gnome 14.04.2 - 64-bit. Memory 8Gb, Intel® Core™ i5-3570K CPU @ 3.40GHz × 4, Gallium 0.4 on AMD CAICOS.
The 2.9 first of the patch of Michael Henning in August 11, was working well with the rulers.
The 2.8.14 stable - ppa otto, is working well.
git log on my 2.9 git master >
commit 72617e42b426e6788c075539a20df7365d2cf102 Author: Michael Henning
Date: Tue Aug 11 16:20:59 2015 -0400
Bug 736411 - Ruler updates cause slowdown when painting
We now avoid drawing rulers in the position property setter and use gtk's region invalidation instead. Previously, we were basically redrawing the ruler inside the mouse event handler, which is pure evil.
thanks
Michael Henning
2015-09-06 21:49:35 UTC (over 9 years ago)
Please update to latest gimp master and test. I think I fixed this.
commit 3233a70bae756e8f62fb144cbce9d8f84ed25609 Author: Michael Henning
Date: Sun Sep 6 00:05:32 2015 -0400
libgimpwidgets: Avoid updating the rulers too often.
Ever since 72617e42b, whenever the user generated a lot of mouse input, we would constantly queue redraws to the rulers. These redraws had a higher idle priority than updating the canvas, so we would rarely get around to canvas updates, which made certain tools (painting with dynamics, the blend tool) feel very unresponsive.
This fixes it by only redrawing the rulers if the mouse has moved far from the last location, or if there are no idle handlers with a priority above LOW.
From, drawoc
thanks
Americo Gobbo
2015-09-06 22:39:57 UTC (over 9 years ago)
Michael, is working fine! I've tested with and no rulers and the performance is equal!
Thanks.
J. Americo Gobbo [Illustrator and Painter] Website | Blog
| Flickr |
Pinterest | Twitter
| Facebook
From, drawoc
thanks
