gimp: gtk3-port
7 of 7 messages available
gimp: gtk3-port Jiří Podhorský 01 Jun 18:56
  Fwd: gimp: gtk3-port Jiří Podhorský 08 Jun 10:56
   Fwd: gimp: gtk3-port Alexandre Prokoudine 08 Jun 11:00
    Fwd: gimp: gtk3-port Jehan Pagès 08 Jun 14:44
  gimp: gtk3-port Michael Natterer 09 Jun 20:28
   gimp: gtk3-port Michael Natterer 09 Jun 22:08
    gimp: gtk3-port Jiří Podhorský 11 Jun 08:39
Jiří Podhorský
2015-06-01 18:56:35 UTC (almost 10 years ago)
gimp: gtk3-port
can you please update branch gtk3-port?
I got a error about uncompatibility between newest gegl from git and gtk3-port of gimp during the compilation:
CC gimplayer.lo gimplayer.c: In function ‘gimp_layer_new_from_surface’: gimplayer.c:290:43: error: incompatible type for argument 3 of ‘gegl_buffer_copy’
gegl_buffer_copy (src_buffer, NULL, dest_buffer, NULL); ^ In file included from /usr/include/gegl-0.3/gegl.h:30:0, from gimp.h:25,
from gimplayer.c:27: /usr/include/gegl-0.3/gegl-buffer.h:372:17: note: expected ‘GeglAbyssPolicy {aka enum }’ but argument is of type ‘GeglBuffer * {aka struct _GeglBuffer *}’
void gegl_buffer_copy (GeglBuffer *src, ^
gimplayer.c:290:7: error: too few arguments to function ‘gegl_buffer_copy’ gegl_buffer_copy (src_buffer, NULL, dest_buffer, NULL); ^
from gimplayer.c:27: /usr/include/gegl-0.3/gegl-buffer.h:372:17: note: declared here void gegl_buffer_copy (GeglBuffer *src, ^
Makefile:1202: recipe for target 'gimplayer.lo' failed make[2]: *** [gimplayer.lo] Error 1
Thank you.
Best regards, Jiri
Jiří Podhorský
2015-06-08 10:56:33 UTC (almost 10 years ago)
from gimplayer.c:27: /usr/include/gegl-0.3/gegl-buffer.h:372:17: note: expected ‘GeglAbyssPolicy {aka enum }’ but argument is of type ‘GeglBuffer * {aka struct _GeglBuffer *}’ void gegl_buffer_copy (GeglBuffer *src, ^
Thank you.
Best regards, Jiri
2015-06-08 11:00:24 UTC (almost 10 years ago)
Jiří,
That branch is not actively being worked on. Right now it's a low priority. We welcome contributions though.
Alex
Jehan Pagès
2015-06-08 14:44:36 UTC (almost 10 years ago)
Jiří,
This said, just rebasing the branch (which is simply the problem here, I think, because there indeed has been some recent changes on GEGL which would make old GIMP code not buildable) is not very difficult, but it still takes time (because after a while, you end up with some merge issues here and there). So we do it usually when we actually want to work on this branch for a reason or another. But as Alexandre says, this is very low priority (2 major versions away!) so that does not happen a lot.
I would simply advise you to rebase the branch locally if all you need is having it build.
Of course if what you want is working on it and provide code, yes patches are much welcome.
Jehan
Alex
Michael Natterer
2015-06-09 20:28:40 UTC (almost 10 years ago)
gimp: gtk3-port
Yeah will do that soon, in the meantime just rebase locally :)
Regards, --Mitch
Thank you.
Best regards, Jiri
Michael Natterer
2015-06-09 22:08:42 UTC (almost 10 years ago)
gimp: gtk3-port
Done.
Thank you.
Best regards, Jiri
Jiří Podhorský
2015-06-11 08:39:54 UTC (almost 10 years ago)
gimp: gtk3-port
Thank you Michael.
2015-06-10 0:08 GMT+02:00 Michael Natterer :
Done.
Thank you.
Best regards, Jiri
