Gradient flares vs Lens flares filters
5 of 7 messages available
Gradient flares vs Lens flares filters Joseph Bupe 15 May 10:53
  1431689797836.1629464689@boxbe 15 May 12:05
   Gradient flares vs Lens flares filters Joseph Bupe 15 May 11:58
    1431692434665.1629464689@boxbe 15 May 12:55
     Gradient flares vs Lens flares filters Joseph Bupe 15 May 12:54
    Gradient flares vs Lens flares filters Alexandre Prokoudine 15 May 12:05
  Gradient flares vs Lens flares filters Alexandre Prokoudine 15 May 11:27
Joseph Bupe
2015-05-15 10:53:20 UTC (almost 10 years ago)
The Gradient Flares filter used to be better than the Lens flares.
Are there any plans for bringing them back?
Joseph
2015-05-15 11:27:47 UTC (almost 10 years ago)
None of them has been removed. Please clarify what you mean.
Alex
Joseph Bupe
2015-05-15 11:58:33 UTC (almost 10 years ago)
Hi Alexandre,
I was referring to Gimp 2.9 development version. I do not see the Gradient Flare under Filters > Light and Shadow.
Regards.
Joseph
2015-05-15 12:05:18 UTC (almost 10 years ago)
On Fri, May 15, 2015 at 2:58 PM, Joseph Bupe wrote:
Hi Alexandre,
I'm running a build from May 7, and Gradient Flare is right in front of me.
Alex
Joseph Bupe
2015-05-15 12:54:25 UTC (almost 10 years ago)
That's consoling to know. But the gradient flares are not in the nightly builds from *nightly*.darkrefraction.com
Thanx for the confirmation Alex.
Joseph
