Move parse/to_xml to GeglNode?
Move parse/to_xml to GeglNode? Gabriel Burt 18 Feb 03:58
Move parse/to_xml to GeglNode? Øyvind Kolås 18 Feb 12:18
Gabriel Burt
2007-02-18 03:58:06 UTC (about 18 years ago)
While working on gegl-sharp I noticed that it would seem to make more sense to have gegl_parse_xml be a static method in GeglNode and gegl_to_xml be an instance method of GeglNode. Just a suggestion. Thanks!
Gabriel
Øyvind Kolås
2007-02-18 12:18:27 UTC (about 18 years ago)
Maybe they should be renamed gegl_node_parse_xml and gegl_node_to_xml. They will not be merged into gegl-node.c anyways that file is too big and needs to be split up. I am even tempted to only rename gegl_node_to_xml and keep gegl_parse_xml as a global function.
The XML format isn't stabilized and thus we should probably have avoided exposing it in the API. But they are useful and do work. The fact that the XML format is in flux should probably be more strongly indicated in the API documentation.
/Øyvind K.
