Selections to shapes
Selections to shapes Joseph Bupe 20 Mar 09:01
  Selections to shapes Joao S. O. Bueno 20 Mar 14:38
   Selections to shapes Joseph Bupe 20 Mar 15:03
Joseph Bupe
2015-03-20 09:01:55 UTC (about 10 years ago)
It would be nice to have controls for tweaking rectangle and ellipse selections into different shapes for designing pixel-based graphics with easy. Currently, the rectangle selections can only be tweaked into a rounded-corners shape. This should be extended further to allow shaping selections into different forms based on the type of the starting selection.
Such design shapes can then be filled with colour, stroked, beveled, embossed etc.
Regards.
Joseph
Joao S. O. Bueno
2015-03-20 14:38:08 UTC (about 10 years ago)
Try using "Select->To Path" --
Everything you describe is already possible.
Although, maybe, selection->To path could have more usability if it would change to the Path Tool, with the new path as active, so that its nodes are displayed at once. Currently, one has to manually go to the Paths dockable, set the path as visible, select the Path Tool and click on the path (4 separate actions) before being able to see the handles.
js
Regards.
Joseph _______________________________________________ gimp-developer-list mailing list
Joseph Bupe
2015-03-20 15:03:37 UTC (about 10 years ago)
Hi Joao.
I know about the selection to paths, but it's not as rich and interactive as I am proposing.
What I had in mind is something like Arakne's Path-Shape-Creator here http://www.arakne.es/en/dessign/gimp-python-script-shape-creator-shapes/
In fact, Ajay Ramanathan's proposed combined-selection tool here : https://git.gnome.org/browse/gimp/log/?h=soc-2013-combined-selection-tool contains some possibility to create n-polygon shapes, just working with selections (not paths). I just thought from that angle it would be nice to consider other possible design shapes as well.
Regards.
Joseph
