Looking for applications for this math idea
7 of 7 messages available
Looking for applications for this math idea Ben Thurston 27 Feb 20:56
   Looking for applications for this math idea Ben Thurston 27 Feb 21:09
    Looking for applications for this math idea Nathan Summers 28 Feb 04:29
     Looking for applications for this math idea Bill Skaggs 28 Feb 13:54
      Looking for applications for this math idea Nathan Summers 28 Feb 16:03
      Looking for applications for this math idea jcupitt@gmail.com 28 Feb 16:37
Ben Thurston
2015-02-27 20:56:23 UTC (over 10 years ago)
I developed this type of function that I feel is sort of like the statistical analogue of the Fourrier series, it breaks a distribution up into simple normal distribution components as the Fourrier series breaks a wave into simple sine wave components. I thought maybe there could be an application for it in image processing but I don't know enough about image processing to figure out how it would apply... Anyone have any ideas?
Ben Thurston
2015-02-27 20:56:56 UTC (over 10 years ago)
Sorry of course you need the link: http://benpaulthurstonblog.blogspot.com/2015/02/supposing-you-have-process-that-reaches.html
Ben Thurston
2015-02-27 21:09:41 UTC (over 10 years ago)
Well I guess I should add that it also interpolates the known points of a distribution...
Nathan Summers
2015-02-28 04:29:59 UTC (over 10 years ago)
The first thing that comes to mind is that it might be a good method for resizing images.
Rockwalrus
breaks a
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp- developer-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
Bill Skaggs
2015-02-28 13:54:13 UTC (over 10 years ago)
Decomposing a distribution into Gaussians is the essence of unblurring. A good algorithm for doing that would of course be very useful, but there is an enormous literature on the topic, and the most important fact about it is that it is mathematically ill-posed. In other words, unless you add extra constraints, tiny changes in the source distribution result in very large changes in the output. (In image-processing terms, transforms of that type tend to create large artifacts.) Unless the new method has some way of handling that problem, it probably isn't going to be useful.
Bill
Rockwalrus
On Fri, Feb 27, 2015 at 3:56 PM, Ben Thurston <
benpaulthurston@gmail.com
up
breaks a
an
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
Nathan Summers
2015-02-28 16:03:50 UTC (over 10 years ago)
Good points.
Rockwalrus
Bill
Rockwalrus
of a
distribution...
distribution
up
breaks a
be
an
ideas?
jcupitt@gmail.com
2015-02-28 16:37:50 UTC (over 10 years ago)
Denoising is another obvious application. You could perhaps do your decomposition at various points over the image surface and see if you can find some noise function that's present everywhere and that therefore comes from the sensor rather than the object.
Again, there is a huge literature and it's a difficult problem.
http://en.wikipedia.org/wiki/Noise_reduction
up
breaks a
an
