Need help with Python plugin exporting to raw file (using Gimp 2.9)
Alek _
2015-02-20 01:06:07 UTC (almost 10 years ago)
I'm using Gimp 2.9 experimental build, which I downloaded from partha.com, to specifically have edit ability with 16-bit per channel images. I originally posted in gimpforums.com and was told I should try here.
I'm trying to write a Python plugin to export an image as a raw file (just data, no header). The current option to export as raw image data (File -> Export as -> Raw image data) seems to only support writing out as 8-bit even when the image precision is greater than 8-bit. So I wanted to write a plugin so I could export my 16-bit per channel image to a raw file with the 16-bit data preserved.
My image is a 16-bit grayscale 3x3 image with a checkerboard pattern of alternating white and black pixels.
I used the sample script 'test-discolour-layer-v4.py' from http://registry.gimp.org/node/28124 as a guide on how to iterate through every pixel. I have some questions and ran into some problems. What I have so far can be seen here (http://pastebin.com/U49VZYVT). It just iterates through the pixels and outputs values to the error console.
1. How do I query for the precision? That is, I want to know if the current image is 8-bit gamma integer, or 16-bit linear integer, or something else. I looked at the image object's attributes and didn't find anything.
2. When I get the pixel value from srcTile[x,y], the value is always 8-bit. With the white pixels, the value should be 65535 but I got 255. How do I get the proper value? When I use the Color Picker tool with info window, it says 65535 for white. How do I get that value?
3. My code creates a new layer from visible and then queries the pixels from that. In my image, all values returned are 255 even for the black pixels. When I put my checkboard pattern on the Background layer and query that layer, I get correct values (though in 8-bit). For any other layer other than Background, the values are always 255. I don't know what I'm doing wrong.
Can someone help me or point me in the right direction?
Thanks.
Joao S. O. Bueno
2015-02-20 11:50:18 UTC (almost 10 years ago)
Hi Alek_
it turns out that the Python bindings for GIMP had not been updated to deal with higher precision images as of yet.
Don't despair - since you had built GIMP master, this is as good time as any to get it going. :-)
You can get to know the image precision (and even set it) thorugh the PDB, though, with a call to:
pdb.gimp_image_get_precision
Now - for the actual business: I think there are two ways to go - one short term, with
a "get" and "set" buffer method on Python drawables that will just copy the inner image data
and make it available in a Python array. That would suffice for most needs like yours, I guess.
The other, longer term and proper way, is to write calls to get the proper GEGL Buffer objects
in Python, using GEGL Python bindings - that will allow the use of any of GEGL's operations
on GIMP Image data and commit it back - but it will also require the python-gegl package.
Those bindings are currently living in my personal repo, and could work for you right now, as they do allow access to the buffer data - but you have to build GEGL with the extra "--enable-introspection" switich to get then going.
(http://github.com/jsbueno/python-gegl )
But -- let's focus in enabling one to get the high-depth pixel contents from GIMP without need for those for now. Feel free to poke me again in 24 hours if there are no news on this subject.
Thanks.
Joao S. O. Bueno
2015-02-21 02:49:23 UTC (almost 10 years ago)
Getting there... no need to poke me for now -
GIMP 2.9.1 Python Console Python 2.7.5 (default, Nov 3 2014, 14:26:24) [GCC 4.8.3 20140911 (Red Hat 4.8.3-7)]
img = gimp.image_list()[0]
a = img.layers[0].get_data()
len(a)
1228800
a[0:300]
array('f', [0.0003035269910469651, 0.0003035269910469651, 0.0003035269910469651, 0.6235294342041016, 0.0003035269910469651, 0.0003035269910469651, 0.0003035269910469651, 0.6235294342041016, 0.0003035269910469651,...]
On 20 February 2015 at 09:50, Joao S. O. Bueno wrote:
Hi Alek_
Thanks.
Joao S. O. Bueno
2015-02-21 04:54:51 UTC (almost 10 years ago)
Hi -
I've actually comitted the above method - but beware it is subject to some changes.
I've added the "precision" read-only property to gimp-images, and the "get_data" method
to drawables (layers and channels) - get_data returns a Python array.array object - it even features conveninent methods
to write itself to a file (https://docs.python.org/2/library/array.html) - For now, it takes an optional string argument representing a BABL pixel format (http://gegl.org/babl/BablFishPath.html) and will return an array of the apropriate data type.
The default is "RGBA float" - but I think it would be better to change it to default to the
drawable native data type- still allowing an explicit format to be passed.
I will probably keep it the return type an array, but possibly subclass it to an object that can
take in 2D indexes to ease pixel access, as currently existing python "pixel_region" object allows
(thus: data[100, 50] will be as valid as data[50 * drawable.width + 100] to get to a single pixels.
On the short term roadmap there is a "set_data" - (or maybe "blit ")?
And at the point in time it is possible to use gobject introspection along pygimp (it can't be done in a straightforward way), make drawable.get_buffer directly available and returning a Gegl buffer wrapped in a convenient Python object.
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
Partha Bagchi
2015-02-21 12:35:43 UTC (almost 10 years ago)
Hi João,
What's your timeframe for modifying pygimp to use introspection? I have not yet built glib and friends with introspection because it's a pain and it's finicky. :)
Thanks, Partha
On Fri, Feb 20, 2015 at 11:54 PM, Joao S. O. Bueno wrote:
Hi -
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
Joao S. O. Bueno
2015-02-21 13:11:27 UTC (almost 10 years ago)
On 21 February 2015 at 10:35, Partha Bagchi wrote:
Hi João,
No idea on "timeframes" . Introspection as it is now, since GIMP itself does not make use of it,
is mostly needed for the UI parts of Pygimp. (i.e. changing from traditional pygtk
to gobject introspection gtk) - but I jsut remebered the major blocker there: GUI building with gobject introspection is known not to work well with GTK2 - we'd
need to change pygimp to gtk3.
That would not be a problem for Linux systems (hey, Pygimp used TCL based Tk widgets when it first debut), it should be a nono for packagers for Mac OS X and Windows.
Can someone who works on the installers give me some feedback on that?
Thanks,
Partha
Hi -
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
Partha Bagchi
2015-02-21 16:18:49 UTC (almost 10 years ago)
It should not be a problem I think since I work on both Mac and Windows. GTK3 and friends build just fine for me on those platforms.
What problems are you envisaging?
Thanks, Partha
Hi João,
Thanks,
Partha
Hi -
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
Alek _
2015-02-21 18:46:38 UTC (almost 10 years ago)
Where did you commit the changes? I looked at https://github.com/jsbueno/python-gegl and it says the last commit was Jun 6, 2014.
I did find a way to get my values. I found out that if I enable precision (pdb.gimp_plugin_enable_precision), the pixel array from srcTile[x,y] will contain the higher precision data. I just need to concatenate the high/low bytes together through bit shifting. The comments for gimp_plugin_enable_precision says "Switches this plug-in to using the real bit depth of drawables" but I don't understand what that means. Is this a compatibility thing, to make sure older stuff that always assumed 8-bit will still work? So you're supposed to enable precision if you want to access to the new higher bit depth?
Date: Sat, 21 Feb 2015 02:54:51 -0200 Subject: Re: [Gimp-developer] Need help with Python plugin exporting to raw file (using Gimp 2.9) From: gwidion@gmail.com
To: spectatoe@outlook.com
CC: gimp-developer-list@gnome.org
Hi - I've actually comitted the above method - but beware it is subject to some changes.
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
Joao S. O. Bueno
2015-02-21 18:58:10 UTC (almost 10 years ago)
Yes - it works nicely for what it does - enabling access to gegloperators, but tehre are new features needed (and bit-rot to avoid)
Yes - I did not know this call, but it certainly is there for this reason - The commits from yesterday on pygimp however, will make it more straightforward,
The old way (tiles nad pixel regions) will be kept, if it is kept, just for compatibility reasons.
len(a)
1228800
a[0:300]
Hi Alek_
Thanks.
