GiMP Help
GiMP Help pamason1129 16 Jan 03:44
  GiMP Help Mike Williams 16 Jan 21:32
pamason1129
2015-01-16 03:44:32 UTC (almost 11 years ago)
GiMP Help
I deeply apologize if this isn't the right place for having problems with GIMP, but I cannot find anywhere else to get software support on this.
I tried using the latest version of GIMP on my Macbook Pro (OS X 10.9.5 Mavericks & 10.10.1 Yosemite) but it came with a serious problem with jagged cursor and drawing movement. I never had this problem with GIMP 2.6, but this latest version seems to have serious problems for me in which when I try to draw a line with either my tablet pen or mouse, it comes out extremely jagged and laggy. (I can provide a video example of what I'm experiencing if I'm not being clear enough)
Is there any way to get better stabilization and less lag with this bad cursor movement?
Thank you, Patrick
Mike Williams
2015-01-16 21:32:48 UTC (almost 11 years ago)
GiMP Help
You will probably have better luck with the user list instead of the dev list.
I do not have access to a mac at the moment. I have not seen the problem you describe.
Mike
