No dds= annoying
No dds= annoying Nathan 10 Jan 22:13
  No dds= annoying Alexandre Prokoudine 11 Jan 12:57
   No dds= annoying Partha Bagchi 11 Jan 13:42
    No dds= annoying Alexandre Prokoudine 11 Jan 13:49
     No dds= annoying Partha Bagchi 11 Jan 14:46
Nathan
2015-01-10 22:13:23 UTC (over 10 years ago)
No dds= annoying
Why not include DDS format? Getting a plug-in to work on mac with it is a fudging pain in the behind
Annoying as fudge.
2015-01-11 12:57:29 UTC (over 10 years ago)
No dds= annoying
11 янв. 2015 г. 16:20 пользователь "Nathan" написал:
We are a small team. Every bit of new code should have a maintainer, otherwise it will get broken eventually, and there will be noone to take care of it.
We know that people have problems with the third-party DDS plugin at least on Windows. Adding the plugin to the default GIMP installer wiĺl not magically fix everythng that is broken.
Alex
Partha Bagchi
2015-01-11 13:42:24 UTC (over 10 years ago)
No dds= annoying
https://code.google.com/p/gimp-dds/ seems to be an active project with roadmaps and all.
For Mac, you can build it yourself or ask someone to do it for you.
Alex _______________________________________________ gimp-developer-list mailing list
2015-01-11 13:49:19 UTC (over 10 years ago)
No dds= annoying
1) It's inactive for the past two years or so. 2) Its Windows build are known to fail to work.
Alex
Partha Bagchi
2015-01-11 14:46:53 UTC (over 10 years ago)
No dds= annoying
Alex,
Minor quibble. :) The last SVN date is December 2013. Also, for fun, I download the source and built it for 2.8 series. Seems to work fine. I was able to load DDS files and write DDS without crash on Win 8.1 64bit.
Thanks,
Partha
