Clamping results to valid range
Clamping results to valid range Nanley Chery 21 Dec 15:39
  Clamping results to valid range Øyvind Kolås 21 Dec 16:27
Nanley Chery
2014-12-21 15:39:02 UTC (over 10 years ago)
Why don't operations like gegl:add and gegl:multiply clamp the resulting values between 0.0 and 1.0? Won't this potentially result in garbage rgb values?
Thanks,
Nanley
Øyvind Kolås
2014-12-21 16:27:46 UTC (over 10 years ago)
The RGB values used by GEGL are not bounded by the gamut of a color space. Out of gamut values are not garbage, but can occur both as intermediate/temporary values - in operations like unsharp mask, as well as for HDR[1] and if the RGB data originates in a color space with a larger gamut than the one currently used.
If any operation, or an application like GIMP, requests the data with an 8bit or 16bit representation the data is clamped then.
1: http://en.wikipedia.org/wiki/High-dynamic-range_imaging
/pippin
