Composite operations
Composite operations Nanley Chery 15 Dec 22:00
  Composite operations Manuel Quiñones 15 Dec 22:13
  Composite operations Florian Klemme 16 Dec 06:59
  Composite operations Øyvind Kolås 16 Dec 10:02
Nanley Chery
2014-12-15 22:00:06 UTC (almost 11 years ago)
Hi all,
Is there a way for an operation (e.g. blur) to call another operation (e.g. rotate) in it's process function?
Thanks, Nanley
Manuel Quiñones
2014-12-15 22:13:19 UTC (almost 11 years ago)
Hi Nanley,
the idea of GEGL is that you can compose by chaining operations. GEGL is a graph based image processing, and each operation is a node in a graph. To connect the output of the blur node to the input of the rotate node, see http://www.gegl.org/api.html#Making_connections
2014-12-15 19:00 GMT-03:00 Nanley Chery :
Hi all,
Thanks, Nanley
_______________________________________________ gegl-developer-list mailing list
List address: gegl-developer-list@gnome.org List membership:
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
.. manuq ..
Florian Klemme
2014-12-16 06:59:44 UTC (almost 11 years ago)
Hi Nanley,
there is function called "attach" that you can override in your filter. It says "override this if you are creating a GeglGraph" in its comment. I'm really not sure about this as I never used it in any way, but maybe this is the right place if you want to create any child nodes / call other filters within your filter. However I've never seen this before, so it might be a very bad idea, at least style-wise.
Florian
Am 15.12.2014 23:00, schrieb Nanley Chery:
Hi all,
Thanks, Nanley
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Øyvind Kolås
2014-12-16 10:02:57 UTC (almost 11 years ago)
Composite operations do exist, in GEGL they are called meta-operations, some examples are gegl:unsharp-mask, gegl:dropshadow and gegl:difference-of-gaussians. It would also be possible, though more cumbersome, to run a GEGL graph as part of the implementation of a GEGL operation; off-hand I am not sure of such an example.
