Problems installing gegl
Problems installing gegl cazaciuc gabriel 12 Feb 18:01
Problems installing gegl Øyvind Kolås 13 Feb 15:18
cazaciuc gabriel
2007-02-12 18:01:41 UTC (about 18 years ago)
I have a problem installing gegl: when i run autogen.sh it doesn't find babl( babl 0.0.12 has been previously installed with ./configure, make and make install). The variabile PKG_CONFIG_PATH is initialy empty and it recommends me to point this variabile to a directory containing babl.pc. I did a complete search of my system and found that there are two directories contraining babl.pc: /usr/local/lib/pkgconfig and the directory containing the source for babl. I set PKG_CONFIG_PATH to these 2 directories but that doesn't change anything. My system is Fedora 4.Here's the output of autogen.sh:
I am testing that you have the tools required to build the GEGL project from SVN. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
checking for libtool >= 1.4 ... yes (version 1.5.16) checking for autoconf >= 2.54 ... yes (version 2.59) checking for automake >= 1.7 ... yes (version 1.9.5) checking for ruby ... yes
checking for glib-gettextize ... yes (version 2.12.9) generating atop.c
generating atop_reverse.c
generating clear.c
generating dst.c
generating in_reverse.c
generating out.c
generating out_reverse.c
generating over.c
generating src.c
generating under.c
generating xor.c
generating in.c
generating add.c
generating subtract.c
generating multiply.c
generating divide.c
generating gamma.c
generating normal.c
generating svg_multiply.c
generating screen.c
generating darken.c
generating lighten.c
generating average.c
generating difference.c
generating negation.c
generating exclusion.c
generating overlay.c
generating hard_light.c
generating soft_light.c
generating color_dodge.c
generating soft_dodge.c
generating color_burn.c
generating soft_burn.c
generating blend_reflect.c
generating subtractive.c
377:function name mismatch gegl_processor_get_type!=GeglProcessor
I am going to run ./configure with the following arguments:
--enable-maintainer-mode
If you wish to pass additional arguments, please specify them on the ./autogen.sh command line or set the AUTOGEN_CONFIGURE_ARGS environment variable.
operations/affine/Makefile.am:6: SOBJS multiply defined in condition TRUE ... operations/Makefile-operations.am:6: ... `SOBJS' previously defined here operations/affine/Makefile.am:1: `operations/Makefile-operations.am' included from here
Running ./configure...
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk
checking whether make sets $(MAKE)... yes checking for gcc... gcc
checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking build system type... i686-redhat-linux-gnu checking host system type... i686-redhat-linux-gnu checking for a sed that does not truncate output... /bin/sed checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... f95
checking whether we are using the GNU Fortran 77 compiler... yes checking whether f95 accepts -g... yes checking the maximum length of command line arguments... 32768 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool
appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes appending configuration tag "F77" to libtool checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes checking for f95 option to produce PIC... -fPIC checking if f95 PIC flag -fPIC works... yes checking if f95 supports -c -o file.o... yes checking whether the f95 linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking whether to enable maintainer-specific portions of Makefiles... yes checking for library containing strerror... none required checking for a BSD-compatible install... /usr/bin/install -c checking whether make sets $(MAKE)... (cached) yes checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... 64 checking for _LARGE_FILES value needed for large files... no checking whether to turn on debugging... no checking whether to turn on profiling... no checking for aclocal flags...
checking for target architecture... i686-redhat-linux-gnu checking for some Win32 platform... no checking for native Win32... no
checking for pkg-config... /usr/bin/pkg-config checking for babl >= 0.0.12... Package babl was not found in the pkg-config search path. Perhaps you should add the directory containing `babl.pc' to the PKG_CONFIG_PATH environment variable No package 'babl' found
configure: error: Library requirements (babl >= 0.0.12) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Configure failed or did not finish!
Food fight? Enjoy some healthy debate in the Yahoo! Answers Food & Drink Q&A.
Øyvind Kolås
2007-02-13 15:18:58 UTC (about 18 years ago)
setting PKG_CONFIG_PATH to
/usr/local/lib/pkgconfig by doing
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig
should be sufficient.
I do not personally use Fedora so I do not know if there is something else you should do as well.
/Øyvind K.
