GEGL OpenCL Porting
| CAJDL4uKB5fiDWTr16jSQ1GNR+j... | 19 Nov 01:07 | |
| CAGYqjdtWOotSFyVkuD0vS3k6Bi... | 19 Nov 01:07 | |
| CAJDL4uJyBVHrw0UmvFQJ+ZAanS... | 19 Nov 01:07 | |
| GEGL OpenCL Porting | Victor Oliveira | 19 Nov 01:06 |
| GEGL OpenCL Porting | Nanley Chery | 19 Nov 01:22 |
| GEGL OpenCL Porting | Nanley Chery | 19 Nov 05:57 |
| GEGL OpenCL Porting | Nanley Chery | 19 Nov 19:26 |
| GEGL OpenCL Porting | Victor Oliveira | 19 Nov 19:33 |
| GEGL OpenCL Porting | Øyvind Kolås | 19 Nov 20:11 |
| GEGL OpenCL Porting | Nanley Chery | 19 Nov 22:32 |
| GEGL OpenCL Porting | Victor Oliveira | 19 Nov 22:33 |
| GEGL OpenCL Porting | Nanley Chery | 19 Nov 22:41 |
| GEGL OpenCL Porting | Victor Oliveira | 20 Nov 07:00 |
| GEGL OpenCL Porting | Nanley Chery | 21 Nov 03:59 |
| GEGL OpenCL Porting | Victor Oliveira | 21 Nov 06:45 |
| GEGL OpenCL Porting | Øyvind Kolås | 21 Nov 10:18 |
GEGL OpenCL Porting
Hi Nanley,
I'd recommend you follow operations/common/brightness-contrast.c file for a point-filter operation (i.e. a pixel-wise filter) instead of doing what you did.
Notice that in operations/common/brightness-contrast.c#n153 there's a string brightness_contrast_cl_source which is a string in opencl/brightness-contrast.cl.h, these are auto-generated files from the kernels in the opencl folder.
Let me know what happens from that.
Victor
On Tue, Nov 18, 2014 at 4:45 PM, Nanley Chery wrote:
Hi Victor,
Thank you very much for taking a look. I understand about the time.
Here's the link to my bitbucket branch: https://bitbucket.org/nanoman281/gegl-cse6230/branch/vid_upstrm
The latest commit is what's causing the video-degradation.xml test to fail (I'm testing using run-compositions.py).
Nanley
On Tue, Nov 18, 2014 at 5:11 PM, Victor Oliveira wrote:
Hi Nanley,
Just to let you know, I'll need some time to answer that because I'll need to build GIMP on my new laptop.
Can you share your code so I can give a look?
Victor
On Tue, Nov 18, 2014 at 12:49 PM, Nanley Chery wrote:
Hi Victor,
I'm a student working on OpenCL porting work for my High Performance Computing class. I'm trying to implement an OpenCL port for the newly-committed video-degradation operation. Are you willing to provide guidance on the following roadblock?
The issue that I'm finding is that creating a cl_process method and setting
the following variables in gegl_op_class_init is not enough to get the cl_process method called:operation_class->opencl_support = TRUE; point_filter_class->cl_process = cl_process;
If I manually try to call the cl_process function in the process method (like in edge-laplace.c), the program terminates in the gegl_cl_set_kernel_args method without an error from CL_CHECK;
Is there something I'm missing? I apologize for mailing you directly instead
of writing to the mailing list. I'm a little pressed for time, so I opted
for this option.Regards,
Nanley
GEGL OpenCL Porting
Wow. Thank you for the tip, CL_CHECK is now giving me an output.
This is the error message: (lt-gegl:10486): GEGL-video-degradation.c-WARNING **: Error in video-degradation.c:236@cl_process - invalid kernel
I thought that I had followed the kernel compilation process correctly. Do you notice any mistake? I have pushed my latest change to the branch.
Nanley
On Tue, Nov 18, 2014 at 8:06 PM, Victor Oliveira wrote:
Hi Nanley,
Victor
Hi Victor,
fail
Nanley
On Tue, Nov 18, 2014 at 5:11 PM, Victor Oliveira <
wrote:
Hi Nanley,
Victor
Hi Victor,
provide
method
Nanley
GEGL OpenCL Porting
I noticed there was more to the brightness-contrast example. I made the
adjustments concerning the kernel name and parameter values.
The code compiles now. The current problem that I'm experiencing is that
the run-composition.py test for video-degradation passes with an empty
kernel.
I'm not sure which code paths are executing to make this work. Any
pointers? I'll do some grepping of the source tree in the meantime.
Thanks, Nanley
Nanley
Hi Nanley,
Victor
Hi Victor,
fail
Nanley
wrote:
Hi Nanley,
Victor
Hi Victor,
provide
the following variables in gegl_op_class_init is not enough to getthe
method
Nanley
GEGL OpenCL Porting
It seems like the code to initialize and run the opencl kernel was lost in this commit:
https://git.gnome.org/browse/gegl/commit/gegl?id=a206f032f77064cf9bff8590ac83ca5b086b53fd
I'm not familiar enough with the codebase to understand the commit message.
Why was this functionality removed?
Should I add the deleted code into video degradation's process function?
Thanks, Nanley
On Wed, Nov 19, 2014 at 12:57 AM, Nanley Chery wrote:
I noticed there was more to the brightness-contrast example. I made the adjustments concerning the kernel name and parameter values. The code compiles now. The current problem that I'm experiencing is that the run-composition.py test for video-degradation passes with an empty kernel.
I'm not sure which code paths are executing to make this work. Any pointers? I'll do some grepping of the source tree in the meantime.Thanks, Nanley
Nanley
wrote:
Hi Nanley,
Victor
Hi Victor,
fail
Nanley
wrote:
Hi Nanley,
Victor
wrote:
Hi Victor,
provide
method
Nanley
GEGL OpenCL Porting
Hi Nanley,
I was actually giving a look at that this morning and figuring out with Daniel Sabo if that's really the case.
Pippin, did you delete that code on purpose?
Victor
I'm not familiar enough with the codebase to understand the commit message. Why was this functionality removed?
Should I add the deleted code into video degradation's process function?Thanks, Nanley
Nanley
Hi Nanley,
Victor
Hi Victor,
(I'm testing using run-compositions.py).Nanley
wrote:
Hi Nanley,
Victor
wrote:
Hi Victor,
guidance on the following roadblock?The issue that I'm finding is that creating a cl_process method and setting
(like in edge-laplace.c), the program terminates in the gegl_cl_set_kernel_args method without an error from CL_CHECK;Is there something I'm missing? I apologize for mailing you directly
instead
Nanley
GEGL OpenCL Porting
Nope, removal of the code making OpenCL work definetely would have been unintended. The removal must have passed unnoticed in the pursuit of better general thread safety. The profiling done at the time indicated that multi-threaded cpu code outperformed the AMD OpenCL implementation when using my i5 intel multi-core cpu, but surely with some GPUs; OpenCL paths might be faster still.
/pippin
GEGL OpenCL Porting
I'm glad we could find this bug. Rolling back to the older version of gegl-operation-point-filter.c and adding support for enums in gegl-operation.c allows my opencl kernel to run (among other changes). I will rebase my repo on top of master once it's updated. The last issue that I'm having is that I get no entry for gegl:video-degradation when I have instrumentation enabled (GEGL_DEBUG_TIME=1). I've been parsing the output to determine the speed of other opencl implementations. Any suggestions?
Thanks, Nanley
I'm not familiar enough with the codebase to understand the commit message. Why was this functionality removed? Should I add the deleted code into video degradation's process function?
Thanks, Nanley
Nanley
On Tue, Nov 18, 2014 at 8:06 PM, Victor Oliveira < victormatheus@gmail.com> wrote:
Hi Nanley,
Victor
Hi Victor,
fail
Nanley
wrote:
Hi Nanley,
Victor
On Tue, Nov 18, 2014 at 12:49 PM, Nanley Chery <
wrote:
Hi Victor,
Performance
provide
method
directly
instead
Nanley
GEGL OpenCL Porting
Have you tried GEGL_DEBUG=opencl ?
Thanks, Nanley
Thanks, Nanley
Nanley
Hi Nanley,
Victor
Hi Victor,
wrote:
Hi Nanley,
need to build GIMP on my new laptop.Can you share your code so I can give a look?
Victor
wrote:
Hi Victor,
setting
instead
opted
Nanley
GEGL OpenCL Porting
Thanks for the question Victor. I'm actually running a custom perl script to automate the process. Your question led me to find a bug in the script.
Cheers, Nanley
that
output to
Thanks, Nanley
in
this commit:
Thanks, Nanley
that
correctly.
branch.
Nanley
Hi Nanley,
Victor
wrote:
Hi Victor,
to
fail
wrote:
Hi Nanley,
Victor
wrote:
Hi Victor,
setting
the following variables in gegl_op_class_init is not enough toget
the
instead
of writing to the mailing list. I'm a little pressed for time,so
I
opted
Nanley
GEGL OpenCL Porting
I put it back, hopefully everything is alright now.
Victor
Cheers, Nanley
determine the speed of other opencl implementations. Any suggestions?Thanks, Nanley
this commit:https://git.gnome.org/browse/gegl/commit/gegl?id=a206f032f77064cf9bff8590ac83ca5b086b53fd
Thanks,
Do you notice any mistake? I have pushed my latest change to the branch.Nanley
Hi Nanley,
for a point-filter operation (i.e. a pixel-wise filter) instead of doing what you did.Notice that in operations/common/brightness-contrast.c#n153 there's a
string brightness_contrast_cl_source which is a string in opencl/brightness-contrast.cl.h, these are auto-generated files from the kernels in the opencl folder.Let me know what happens from that.
Victor
wrote:
Hi Victor,
fail
wrote:
Hi Nanley,
Victor
wrote:
Hi Victor,
setting
the
method
instead
I
opted
Nanley
GEGL OpenCL Porting
Thanks for the quick fix, it's working on my system.
I noticed that you've enabled GPU's by default due to some testing. Where can I find these results? According to my tests among two operations Edge-laplace and Video-degradation (currently on my bitbucket branches: edge_upstrm, vid_upstrm), OpenCL on my GPU performs 7.8x slower than my CPU.
The following are some results for the Video-Degradation operation. I took the average over 5 trials and the units are in seconds. On my CPU, I was able to achieve a 37.6x average speed up using OpenCL than without it. Enabling multiple threads increases my times ~0.01s.
ImgSize Intel Core i7-2675QM No OpenCL Radeon HD 6450 Speedup from No Opencl GPU Slowdown from CPU 32x32 0.000650425 0.0668745008 0.0014333608 102.8166211323 2.2037295614 64x64 0.0007871332 0.0678992536 0.0021703034 86.2614530806 2.7572250796 128x128 0.0007964746 0.0676906748 0.0048043746 84.9878637687 6.0320499863 256x256 0.0014093932 0.0683310326 0.0154375408 48.4825899543 10.9533243101 512x512 0.0080697294 0.074770076 0.0621315552 9.2654997824 7.6993356432 1024x1024 0.0287260124 0.0886687912 0.2647257696 3.0867072661 9.215541855 2048x2048 0.1051937164 0.1571853124 0.976372136 1.4942462134 9.2816583482 4096x4096 0.4144775556 0.3923948302 4.07693664 0.9467215411 9.8363266838 5197x5543 0.5391386664 0.6064622732 6.9632312602 1.1248725254 12.9154736882
37.6073972516 7.8771850173 Please let me know if you spot anything wrong with my measuring methodology or OpenCL implementation. Also, is the mailing-list and the bugzilla both suitable places to submit patches?
Thanks, Nanley
Victor
script to
Cheers, Nanley
On Wed, Nov 19, 2014 at 5:33 PM, Victor Oliveira <
changes). I
I'm having is that I get no entry for gegl:video-degradation when Ihave
lost
in
Thanks,
NanleyOn Wed, Nov 19, 2014 at 12:57 AM, Nanley Chery <
the run-composition.py test for video-degradation passes with anempty
kernel.
On Tue, Nov 18, 2014 at 8:22 PM, Nanley Chery <
Hi Nanley,
there's
a
string brightness_contrast_cl_source which is a string in opencl/brightness-contrast.cl.h, these are auto-generated filesfrom
Victor
wrote:
Hi Victor,
test
to
fail
wrote:
Hi Nanley,
because
I'll
Victor
wrote:
Hi Victor,
Computing class. I'm trying to implement an OpenCL port forthe
to
provide
method
and
setting
the following variables in gegl_op_class_init is not enoughto
get
the
method
(like in edge-laplace.c), the program terminates in the gegl_cl_set_kernel_args method without an error fromCL_CHECK;
instead
of writing to the mailing list. I'm a little pressed fortime,
so
I
opted
Nanley
GEGL OpenCL Porting
Hi Nanley,
It's cool that you're doing this, it's important work.
About your GPU performance, have in mind that:
1) GEGL is tile-based, so there a memcpy over the whole input when we use the GPU to linearize the image data. Our tile sizes are quite small (128x64 last time I saw it) so it's too much of an overhead to call a CL kernel for such small data, that's why the cl iterator has to go over much larger regions (such as 2048x4096).
2) Besides that, there's the PCIe 2.0/3.0 bus overhead, it is specially a problem for bandwidth-limited filters such as yours, If you have a convolution filter for example, performance is much better on the GPU compared to the CPU.
Even though, there's a lot of speedup that can be gained by chaining multiple operations/filters so that intermediate data never leaves the GPU, that's where the real performance gain is. Consider also that in many filters there's adjustable params where real-time feedback to the user is important. In this case, input data will be uploaded to the GPU only once as long as the image fits completely in the GPU memory. Our CL code has a caching system using the whole GPU memory as a pool.
in the perf folder there's some cool utilities that can be used for simple profiling. In my system I got a Intel GPU which is not a particularly fast GPU:
victorolivs-MacBook-Pro:perf victoroliv$ export GEGL_USE_OPENCL=no
victorolivs-MacBook-Pro:perf victoroliv$ ./test-bcontrast
@ bcontrast: 971.37 megabytes/second
victorolivs-MacBook-Pro:perf victoroliv$ export GEGL_USE_OPENCL=yes
@ bcontrast: 364.53 megabytes/second
victorolivs-MacBook-Pro:perf victoroliv$ ./test-blur
@ gaussian-blur: 163.04 megabytes/second
@ gaussian-blur: 248.08 megabytes/second
I haven't really tried much OpenCL in the CPU, but Pippin should have more information about the performance measurements he did. You can submit patches in the mailing list.
Victor
Thanks, Nanley
Victor
script to
Cheers, Nanley
changes). I
issue
that
lost
in
Thanks,
kernel.
Hi Nanley,
for a point-filter operation (i.e. a pixel-wise filter) insteadof
doing what you did.
there's
a
Victor
wrote:
Hi Victor,
test
to
fail
wrote:
Hi Nanley,
because
I'll
Victor
wrote:
Hi Victor,
willing to
provide
method
and
setting
get
the
method
instead
so
I
opted
Nanley
GEGL OpenCL Porting
Benchmarking GEGL on CPU vs multithreaded CPU vs OpenCL CPU vs GPU is not easy, since different workloads can have very different performance characteristics. With the multi-threaded work I was happy when there was any performance win over single threaded without crashes/visual glitches; since it meant that the concurrency handling of GeglBuffer had improved as intended.
The type of workload I was using for my testing was many chained point composers / point composer-3s with quite large buffer sizes (4096x4096 buffers) which was meant to be representative of multi-layer compositions in GIMP.
For patches, bugzilla is best, since things posted there are found again if for some reason forgotten for a while.
/pippin
