Problem with tiff export from rawtherapee (4.1.80x64) to gimp (2.8.14(v.1)x64)
Asmodis
2014-10-27 13:16:21 UTC (about 11 years ago)
Hello
First of all: I don't really know if the following problem is a problem with gimp, Raw therapee or even Windows. So before creating a new bug-report, I wanted to ask you for some information about this - maybe someone here can tell me more. :)
And this is my problem: When I try to use RawTherapee's export-function in order to edit my images in gimp, the image won't load properly inside gimp. Instead I get the following error messages while gimp starts up (roughly translated from german to english):
--------------------------- script-fu.exe - Entry point not found ---------------------------
The entry point "g_list_free_full" was not found in DLL "C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\script-fu.exe". ---------------------------
--------------------------- file-tiff-load.exe - Entry point not found ---------------------------
The entry point "gdk_win32_window_foreign_new_for_display" was not found in DLL "C:\Program Files\GIMP 2\bin\libgimpui-2.0-0.dll". ---------------------------
And when gimp is finally loaded, I get the following errors: ------------------------------------ Plug-in crashed: "file-tiff-load.exe" (C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\file-tiff-load.exe) The dying plug-in may have messed up GIMP's internal state. You may want to save your images and restart GIMP to be on the safe side. Opening 'C:\Users\Simon\AppData\Local\Temp\_MG_5569.tif' failed: Procedure 'file-tiff-load' returned no return values ----------------------------------
Which seems to be related to the first messages: gimp can't load file-tiff-load.exe on startup, so the tiff-import won't work.
I did some research on this Problem (unsing Process Monitor) and the result was the following:
By starting gimp from RawTherapee, the dll-search includes RT's directory. And since RT is also based on gtk, etc. there are some dlls which have the same name as gimps own dlls, but in another version. The following is an example for gimp/file-tiff-dll.exe searching for gimp's libgimpwidgets-2.0-0.dll. As you can see, RT's directory is searched, before gimp's own directory and this is where the bad things happen (not in this case but I think you can see, what the problem is).
5128 CreateFile C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\libgimpwidgets-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2479470 file-tiff-load.exe 5128 CreateFile C:\Windows\System32\libgimpwidgets-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2482944 file-tiff-load.exe 5128 CreateFile C:\Windows\System\libgimpwidgets-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2486381 file-tiff-load.exe 5128 CreateFile C:\Windows\libgimpwidgets-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a /*19:12:39,2489930 file-tiff-load.exe 5128 CreateFile C:\Program Files\RawTherapee\libgimpwidgets-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a*/ 19:12:39,2496850 file-tiff-load.exe 5128 CreateFile C:\Program Files\GIMP 2\bin\libgimpwidgets-2.0-0.dll SUCCESS Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a, OpenResult: Opened
The following is an example for a dll (libglib-2.0-0.dll), which also exists in RT's folder - as you can see, gimp finds RT's dll, before it finds its own and therefore uses the wrong one.
19:12:39,2502152 file-tiff-load.exe 5128 CreateFile C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\libglib-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2504812 file-tiff-load.exe 5128 CreateFile C:\Windows\System32\libglib-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2506614 file-tiff-load.exe 5128 CreateFile C:\Windows\System\libglib-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a 19:12:39,2508431 file-tiff-load.exe 5128 CreateFile C:\Windows\libglib-2.0-0.dll NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a /*19:12:39,2510259 file-tiff-load.exe 5128 CreateFile C:\Program Files\RawTherapee\libglib-2.0-0.dll SUCCESS Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a, OpenResult: Opened*/
As I already mentioned before, I don't really know if this can even be fixed within gimp's source or whether it has to be fixed somewhere else, so some feedback would be nice.
With respect,
Simon Müller
--- Diese E-Mail ist frei von Viren und Malware, denn der avast! Antivirus Schutz ist aktiv. http://www.avast.com
Asmodis
2014-10-30 23:38:00 UTC (about 11 years ago)
Nobody who can help me with that? :/
Hello
With respect,
Simon Müller
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
Partha Bagchi
2014-10-31 22:31:44 UTC (about 11 years ago)
I tested the latest RT 4.2.1 build with my Gimp builds on Windows. There were no issues that I could detect.
I have informed the OT about this with screenshots.
Hello
With respect,
Simon Müller
