Placing grid on half-pixels using the offset
Placing grid on half-pixels using the offset Seldom Needy 07 Oct 10:36
  Placing grid on half-pixels using the offset Ofnuts 07 Oct 19:28
Seldom Needy
2014-10-07 10:36:30 UTC (over 10 years ago)
Is there a strong reason for fractional offsets (even +0.5) in the grid-configuration dialog being prevented? I'm working on a layout at present and I've noticed this limitation...
Due to the snapping behavior of brushes, it's sometimes helpful to be able to draw/erase/smear/etc along the *middle* of a pixel if -- say -- I'm working with a border or divider-set which is 5 pixels wide. If I can have the pixel immediately under the cursor be centered where the middle pixel will be, I neatly get the remaining four pixels of the current tool's height/width symmetrically on either side... Otherwise I have to rely on rounding-behavior or constantly doing an additional transformation after each change in this part of the work.
Other than having to change one field from "int" to "float", is there a good reason not to add this tweak for those who want it? By default, it would not be available unless someone specifically input a fraction into the grid-settings anyway.
2014-10-07 19:28:12 UTC (over 10 years ago)
For all uses of guides/grid with layers this could be problematic, because layers cannot be positioned on half-pixels.
Did you try to use a path and View>Snap to active path? Path doesn't need to be positioned on integer pixels. If you want a grid of path you can use my path-grid and path-shift scripts that you'll find there: http://sourceforge.net/projects/gimp-path-tools/files/scripts/
