How can I modify GIMP's Menu Hierarchy?
I am working with feature recommendation for complex softwares to enhance users' feature awareness in order to make their future task easier. As a reference software, I use GIMP (about 250 distinct features). For my purpose, I have developed a recommendation system based on RBM which recommends new features that users are unfamiliar with. I already tried to mock up gimp menu hierarchy using Java interface to get a extra bit of freedom to manipulate the menu system to visualize the recommended features. But unfortunately, I am finding it hard to design a userstudy to measure the effect of feature awareness due to the fact that a user is unable to do real task in my prototype interface. Therefore, I need a good understading of gimp's Menu generation code so that I can visualize the recommended features in actual GIMP interface. Since the code base is large, I am finding it hard to track the code. So It would be a great help for me If anyone knows answer to my following questions:
1. source_folder/menus contains a number of xml file for example: images-menu.xml but it doesn't contain all the menuitem names under image menu in actual interface. I want to know which file actuallly generate initial menu in gimp.
Thanks in advance.
Adnan
