Color Tools and Bump Map as Dockable Dialogs
Color Tools and Bump Map as Dockable Dialogs Joseph Bupe 11 Jul 13:38
  Color Tools and Bump Map as Dockable Dialogs Alexandre Prokoudine 12 Jul 10:26
   Color Tools and Bump Map as Dockable Dialogs scl 12 Jul 11:16
  Color Tools and Bump Map as Dockable Dialogs Ofnuts 12 Jul 17:45
Joseph Bupe
2014-07-11 13:38:42 UTC (almost 11 years ago)
Hello Developers,
IMHO, the Color Tools and Bump Map should be turned into dockable dialogs as a way of cleaning up/minimizing the number of po-up dialogs.
All color tools could appear under the same tab as icons and clicking the icon should display corresponding details underneath. Changing values/curves should automatically affect the image; therefore, eliminating the need to click the image in order to access a pop-up dialog. See attached mock-up.
Submitted for your consideration.
joseph
2014-07-12 10:26:00 UTC (almost 11 years ago)
Joseph Bupe wrote:
See the attached mock-up.
It's missing.
Alex
scl
2014-07-12 11:16:46 UTC (almost 11 years ago)
On 12.7.2014 at 12:26 PM Alexandre Prokoudine wrote:
It's missing.
It's here:
http://gimpchat.com/download/file.php?id=14353&sid=8bb304f394a8db0eaa414f3a4e4def6d
BTW: this lets me wonder whether the UI brainstorm is still active or to be revived. I find it a good way to contribute UI ideas and it's still listed as a way to contribute to GIMP.
Kind regards, Sven
2014-07-12 17:45:08 UTC (almost 11 years ago)
On 11/07/14 15:38, Joseph Bupe wrote:
Hello Developers,
For me the question is more why some tools have controls split between the Tool options and a floating dialog. I hardly see the logic to have a floating dialog to show me the Shear/Rotation/Scale parameters when the Rectangle/Ellipse/Crop tools use the Tool options to display equivalent information.
Clicking on the image is not meant to access the dialog, it actually starts the tool on a given image, the dialog is a side effect... (of course in single-window mode it's a bit less useful). The floating dialog could have a meaning if it were image-oriented, i.e. if there were one instance of the tool for each image. This also raise the question of why we have the Tool-centric view where you cannot have a two different tools active at the same time on two different images.
