clean-up project
clean-up project Joseph Bupe 02 Jul 07:14
  clean-up project Alexandre Prokoudine 02 Jul 11:29
   clean-up project Michael Schumacher 02 Jul 15:35
    clean-up project Kevin Payne 02 Jul 15:58
     clean-up project Michael Schumacher 05 Jul 20:54
  clean-up project peter sikking 02 Jul 12:15
Joseph Bupe
2014-07-02 07:14:59 UTC (almost 11 years ago)
clean-up project
A horizontal tool option bar between the toolbox and menu bar is definitely handy as far as accessing properties settings is concerned.
I am happy this will eventually be implemented in Gimp.
Regards.
joseph
2014-07-02 11:29:13 UTC (almost 11 years ago)
clean-up project
Joseph,
Personally, I'd like to see that happen as well. However I have no idea how you arrived at the conclusion that this will be done.Could you please elaborate? Thanks :)
Alex
peter sikking
2014-07-02 12:15:20 UTC (almost 11 years ago)
clean-up project
I was thinking about that, and then I realised that I am not exactly sure what you mean.
do you mean that what is right now in the tool options panel should be layer out in a horizontal bar?
--ps
http://blog.mmiworks.net: on interaction architecture
2014-07-02 15:35:49 UTC (almost 11 years ago)
clean-up project
Gesendet: Mittwoch, 02. Juli 2014 um 13:29 Uhr Von: "Alexandre Prokoudine"
Joseph,
Probably a misunderstanding from Johann's mail?
In general, I miss a bit of skepticism amongst the greater GIMP community - some seem to believe everything that's written somewhere, without requiring or requesting additional proof.
Kevin Payne
2014-07-02 15:58:02 UTC (almost 11 years ago)
clean-up project
You want scepticism? Ok, where would we find that additional proof published? Along with evidence that you are working towards that goal.
Kevin
-- Regards,
2014-07-05 20:54:02 UTC (almost 11 years ago)
clean-up project
On www.gimp.org, docs.gimp.org, and wiki.gimp.org.
And it is a good idea to ask a member of the core development team to verify or falsify the information found there (or anywhere else). A good way to do this are the gimp-developer mailing list and the #gimp irc channel on irc.gimp.org.
In the current case, a simple question like "Is this a decided feature, or a suggestion?" (NB: the latter) would have prevented the (alleged) misunderstanding from happening.
GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D
4CDDhttp://www.selfbound.net/storieslr/ridinglessons4.html
