clean-up project
clean-up project Johann 01 Jul 10:26
  clean-up project Alexandre Prokoudine 01 Jul 23:31
Johann
2014-07-01 10:26:19 UTC (over 11 years ago)
clean-up project
I'd love to see Gimp more functional and less cluttered: lets pick two flies with one slap! zack!
object: (Tabs-dock) -Brush
-Dynamics
-Presets
-Palette
-Gradient
following tabs have a list tab plus an editor tab. These should share the same tab. 1) Double clicking: entering the editor (less used, a double click would work fine) 2) clicking a button in the toggle area of the editor : returning to the list (primarily used)
See a good example here: http://gimp-brainstorm.blogspot.it/search?updated-max=2012-06-20T00:03:00%2B02:00&max-results=7&start=7&by-date=false
following tabs should be merged: -Layers
-Paths
paths should live, like text-layers, in the layers tab. The path tab toggle bar should migrate into the path options of the tool preferences tab.
Furthermore, i'd welcome if a Double click could open the tool preferences tab with relative options of: -Text layer > Text options
-Path layer > Path options
-Layer > Layer options (options in the right-click menu of layers) = additional option in the tool preferences tab
regards
Jo
2014-07-01 23:31:44 UTC (over 11 years ago)
clean-up project
-Dynamics
-Presets
-Palette
-Gradient
Makes sense to me :)
-Paths
Vector layers are on the radar for quite a long time :) So yes, eventually that's going to happen.
Oh? What options?
Alex
