merging some tools
merging some tools Johann 25 Jun 10:11
  merging some tools Richard 26 Jun 15:14
  merging some tools Alexandre Prokoudine 26 Jun 15:37
Johann
2014-06-25 10:11:48 UTC (almost 11 years ago)
merging some tools
i'd suggest to simplify and clean up with all the tool icons around. Merging tools (radio button to change tool behavior in the tool preferences tab)
1) Rectangle/Circle Selection Tool 2) Scissors/Lasso
3) color extractor/foreground extractor 4) Move tool/Align tool
5) Clone/Perspective Clone
regards
Jo
Richard
2014-06-26 15:14:58 UTC (almost 11 years ago)
merging some tools
Date: Wed, 25 Jun 2014 12:11:48 +0200 To: gimp-developer-list@gnome.org
Subject: [Gimp-developer] merging some tools
Hi, i'd suggest to simplify and clean up with all the tool icons around. Merging tools (radio button to change tool behavior in the tool preferences tab)
regards
Jo
If by 'merging' you mean that the GIMP toolbox groups tools into 'families' (preferably with a dropdown menu so you can select the specific tool) then I can support this -- in my GIMP I literally removed half the icons from the toolbox because (1) they're tools I don't use often at all and (2) I wanted to minimize the amount of real estate occupied by the box.
2014-06-26 15:37:27 UTC (almost 11 years ago)
merging some tools
http://blog.mmiworks.net/2011/08/teaching-interaction-10.html
What do you mean with the color extraction tool? I know of no such thing in GIMP :)
http://blog.mmiworks.net/2013/06/teaching-interaction-13.html
Alex
