Python-fu GIMP Layer "parent" property error
Python-fu GIMP Layer "parent" property error Seldom Needy 19 Jun 01:41
  Python-fu GIMP Layer "parent" property error Joao S. O. Bueno 19 Jun 03:31
   Python-fu GIMP Layer "parent" property error Joao S. O. Bueno 20 Jun 01:38
    Python-fu GIMP Layer "parent" property error Ofnuts 20 Jun 07:08
     Python-fu GIMP Layer "parent" property error Joao S. O. Bueno 20 Jun 19:30
Seldom Needy
2014-06-19 01:41:25 UTC (over 11 years ago)
As stated at http://www.gimp.org/bugs/ I'm supposed to mention issues here before throwing them into the tracker so here goes.
Working on a plugin that does some layer manipulation and kept encountering the error:
AttributeError: 'gimp.Layer' object has no attribute 'layers' when trying to access the layer structure in a tree-like fashion to find "sibling" layers in the same grouplayer/layergroup. After being puzzled, I found the issue, which seems to essentially be that the "parent" attribute of a layer automatically "upcasts" to gimp.Layer, rather than yielding a gimp.GroupLayer, as I think should be expected.
The behavior can be reproduced as follows from Python console in GIMP 2.8.8:
image = gimp.image_list()[0]
image.layers[0].layers[0].parent.layers # again with the result:
Assuming an image's layer-structure is similar to: [root image]
+--------GROUPLAYER ZERO
+--------+--------LAYER ZERO OF ZERO +--------GROUPLAYER ONE
+--------+--------LAYER ZERO OF ONE
+--------+--------LAYER ONE OF ONE
+--------LAYER BACKGROUND
From the console we have a hint as to why this is.
image.layers[0]
image.layers[0].layers[0].parent # should return the same layer as above but gives
I haven't seen this on the bugtracker nor was I able to find discussion about it on the listserv archive. I assume it is a platform-independent bug. Can anyone confirm that? I develop on Windows XP at present.
Workarounds for this bug exist I'm not in love with them (inelegant). Regardless, a sketch of what might work without using globals:
def get_all_layers(parent): """-> list. recursively get all layers from either an image, or a GroupLayer Proceeds depth-first.
container=[]
for layer in parent.layers:
container.append(layer)
if hasattr(layer,"layers"):
container.extend( get_all_layers(layer) ) return container
def get_parent(child): if hasattr(child,"parent"):
for layer in get_all_layers(child.image): if layer.name==child.parent.name: return layer #^ layer will have the proper data-type of gimp.GroupLayer, so return it.
#^.. We do this because child.parent yields a gimp.Layer, which is undesired.
else:
return child.image # if we're already top-level, parent must just be the image.
Cheers
- Seldom
Joao S. O. Bueno
2014-06-19 03:31:17 UTC (over 11 years ago)
yes - this is a bug - and it can be open in the bugtracker.
image.layers[0]
container=[]
else:
Cheers
- Seldom
Joao S. O. Bueno
2014-06-20 01:38:28 UTC (over 11 years ago)
Issue fixed in master and 2.8 branch. (It will be generally available as of gimp 2.8.12)
Thanks for spotting that.
image.layers[0]
container=[]
else:
Cheers
- Seldom
2014-06-20 07:08:59 UTC (over 11 years ago)
While we are at it, it there an explanation why there are both "layers" and "children" attributes in a gimp.GroupLayer, that return essentially the same thing but with a different class;
>>> image=gimp.image_list()[0] >>> g=image.layers[0]
>>> print g
>>> g.children
>>> g.layers
In practice, the "children" method is a bit of a pain when you walk the tree, because the image has "layers" but no "children".
But a gimp.Layer has "children" but no "layers"...
All this is highly confusing... with a single "layers" attribute that always returns a GroupLayer when possible things would be simpler IMHO.
Joao S. O. Bueno
2014-06-20 19:30:12 UTC (over 11 years ago)
g=image.layers[0]
print g
g.children
g.layers
Hi -
All drawables descend from GIMP Item - which has the "children" property. The GroupLayer class inheritance order, in pygimp is thus: GroupLayer method. Pygimp mimics that, even though no other kind of item, currently, is a container.
