How to call gimp_export_image() from Python plugin
Hello!
I'm trying to write export plugin for custom image format in Python.
Looking at plugins implemented in C, e.g. gimp/plug-ins/file-bmp/bmp.c, and docs (http://developer.gimp.org/api/2.0/libgimp/libgimp-gimpexport.html) I see, that best and recommended way to convert user image to single layer image with proper capabilities is by using gimp_export_image() function.
How gimp_export_image() can be called from Python?
I can't find it exported Python modules and looks like it's not accessible via PDB either.
If it's not available, can you advice proper alternative? Should I report missing gimp_export_image() function in bug tracker?
Thanks in advance,
Vladimir Rutsky
From Python, in GIMP 2.8, you have to make calls to whatever is
available via the PDB, but
for some calls that have been shortened as methods of Image, Layer and
other objects (but internally,
most things happen through the PDB anyway).
So, you have to call either "pdb.gimp_file_save" and specify the file
format via the file-name extension,
or call "pdb.file_bmp_save". For both cases you have to passin a
drawable to be saved, meaning that if you
want to save an existingimage, you hvae to preceed these calls with
the equivalent of these two lines:
saving_image = pdb.gimp_image_duplicate(img) saving_drawable = pdb.gimp_image_merge_visible_layers(saving_image)
then you have a drawable to save, with all the visible image contents,
but without messing
with the image the user sees. After saving, call
"pdb.gimp_image_delete(saving_image)" - to recover
the resources used by the temporary image,
js -> wrote:
Hello!
Thanks in advance,
Vladimir Rutsky
On Wed, Jun 18, 2014 at 7:32 AM, Joao S. O. Bueno wrote:
From Python, in GIMP 2.8, you have to make calls to whatever is available via the PDB, but
for some calls that have been shortened as methods of Image, Layer and other objects (but internally,
most things happen through the PDB anyway).So, you have to call either "pdb.gimp_file_save" and specify the file format via the file-name extension,
or call "pdb.file_bmp_save". For both cases you have to passin a drawable to be saved, meaning that if you want to save an existingimage, you hvae to preceed these calls with the equivalent of these two lines:saving_image = pdb.gimp_image_duplicate(img) saving_drawable = pdb.gimp_image_merge_visible_layers(saving_image)
then you have a drawable to save, with all the visible image contents, but without messing
with the image the user sees. After saving, call "pdb.gimp_image_delete(saving_image)" - to recover the resources used by the temporary image,js ->
Thank for your reply, but this doesn't solves my problem.
merge_visible_layers() doesn't behave as gimp_export_image(): it only merges image layers to single layer. I need not only to merge them, but also to convert to proper image format suitable for me (e.g. convert to RGB from GRAY or RGBA) and probably some other convertions.
And gimp_export_image() designed specifically for my task.
According to it's sources (https://git.gnome.org/browse/gimp/tree/libgimp/gimpexport.c) there are quite a lot of steps and not so trivial logic that should be done to obtain result image, and I don't want to reimplement this functionality, I want to call gimp_export_image().
On 17 June 2014 19:43, Vladimir Rutsky wrote:
Hello!
Thanks in advance,
Vladimir Rutsky
Vladimir Rutsky
so, just do the needed conversions through further PDB calls.
as you can see, gimp_export_image is not available to plug-ins as of
gimp 2.8 series.
(yes, it should be, and yes you can open a bug report requesting that
so that we don't forget about it,
but this is an API change, so it will just be there for GIMP 2.10 anyway).
js ->
Hello!
Thanks in advance,
Vladimir Rutsky
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list--
Vladimir Rutsky
so, just do the needed conversions through further PDB calls. as you can see, gimp_export_image is not available to plug-ins as of gimp 2.8 series.
(yes, it should be, and yes you can open a bug report requesting that so that we don't forget about it,
Ok, thank you for clarification. I filed bug: https://bugzilla.gnome.org/show_bug.cgi?id=731843
Why it can be released sooner? I'm not familiar with GIMP development
process, but I think exporting additional function doesn't break
backward compatibility of API.
If I'll submit patches for this issue, when I can expect to see it in
some official release of GIMP (in case patches will be accepted)?
-- Vladimir Rutsky
js
->And gimp_export_image() designed specifically for my task.
Hello!
Thanks in advance,
Vladimir Rutsky
Vladimir Rutsky
How to call gimp_export_image() from Pythonplugin
Just to clarify, JS - you say "gimp_export_image is not available to plug-ins as of gimp 2.8 series" - I take it you mean to Python plug-ins? Because it works fine in Gimp-Perl plug-ins.
I'd claim that the lack of gimp_export_image in pygimp is a bug, not a
feature to be added, so it should be possible to add in 2.8. Vladimir, it
ought to be as simple as adding to pygimp gimpexport, in the same way as
there is gimpui. See
Ed J Gimp-Perl guy
-----Original Message-----
Sent: Wednesday, June 18, 2014 1:27 PM
To: gwidion@gmail.com
Cc: gimp-developer
Subject: Re: [Gimp-developer] How to call gimp_export_image() from
Pythonplugin
-- Vladimir Rutsky
js
Hello!
docs
image with proper capabilities is by using gimp_export_image() function.How gimp_export_image() can be called from Python?
via PDB either.If it's not available, can you advice proper alternative? Should I report
missing gimp_export_image() function in bug tracker?Thanks in advance,
Vladimir Rutsky
Vladimir Rutsky
IS it available throught the PDB?
Most GIMP - Python functions are done via PDB, except pixel-region
manipulation stuff.
If it is not in the PDB, it is not availabl in GIMP 2.8 - the current
GIMP Python structure has to
special cases a lot of things to work aside from the PDB, and doing so
is not minor stuff
done inside a release cycle.
Making the 3-4 above calls are straightforward - I see no reason to
violate the principle of no new features inside a release to add this.
In GIMP 2.10, the export feature will also have to deal with precision
management, and besides this export function, a class of PDB calls
dealing with precision needs
to be added as well.
I'd claim that the lack of gimp_export_image in pygimp is a bug, not a feature to be added, so it should be possible to add in 2.8. Vladimir, it ought to be as simple as adding to pygimp gimpexport, in the same way as there is gimpui. See
http://developer.gimp.org/api/2.0/libgimp/libgimp-gimpexport.htmlEd J Gimp-Perl guy
-----Original Message----- From: Vladimir Rutsky Sent: Wednesday, June 18, 2014 1:27 PM To: gwidion@gmail.com
Cc: gimp-developer
Subject: Re: [Gimp-developer] How to call gimp_export_image() from PythonpluginOn Wed, Jun 18, 2014 at 3:19 PM, Joao S. O. Bueno wrote:
but this is an API change, so it will just be there for GIMP 2.10 anyway).Ok, thank you for clarification. I filed bug: https://bugzilla.gnome.org/show_bug.cgi?id=731843
Why it can be released sooner? I'm not familiar with GIMP development process, but I think exporting additional function doesn't break backward compatibility of API.
If I'll submit patches for this issue, when I can expect to see it in some official release of GIMP (in case patches will be accepted)?-- Vladimir Rutsky
js
Hello!
docs
Vladimir Rutsky
Vladimir Rutsky_______________________________________________ gimp-developer-list mailing list
Bottom line - switch to Gimp-Perl!
Ed J
Sent: Wednesday, June 18, 2014 6:52 PM
To: Ed .
Cc: Vladimir Rutsky ; gimp-developer
Pythonplugin
manipulation stuff.
is not minor stuff
On Wed, Jun 18, 2014 at 9:52 PM, Joao S. O. Bueno wrote:
IS it available throught the PDB? Most GIMP - Python functions are done via PDB, except pixel-region manipulation stuff.
If it is not in the PDB, it is not availabl in GIMP 2.8 - the current GIMP Python structure has to
special cases a lot of things to work aside from the PDB, and doing so is not minor stuff
done inside a release cycle.Making the 3-4 above calls are straightforward - I see no reason to violate the principle of no new features inside a release to add this. In GIMP 2.10, the export feature will also have to deal with precision management, and besides this export function, a class of PDB calls dealing with precision needs
Joao, Ed,
so gimp_export_image() should be exported to Python though PDB (to all plugins) or by writing custom export code as done for some functions to export it only to Python?
-- Vladimir Rutsky
Cc: gimp-developer
js
Hello!
docs
Vladimir Rutsky
It is not a PDB function, but a libgimp (C) function. Since pygimp can do gimpui stuff (also C functions), there is no conceptual reason why pygimp shouldn't also handle gimpexport (which is where gimp_export_image lives).
I thought that in Python it was straightforward to access C functions? This is simply a function that returns an integer, albeit one that uses the GIMP UI - which pygimp already can initialise.
Sent: Thursday, June 19, 2014 6:24 PM
To: João Sebastião de Oliveira Bueno
Cc: Ed . ; gimp-developer
Pythonplugin
Joao, Ed,
-- Vladimir Rutsky
This is a missing feature in the 2.8 release. New features are usually not added in stable release cycle, which is the case of gimp 2.8 - and gimp-python is bound to it.
If it was something without which one would die - but the functionality can be obtained by 5 lines of code, as already answered in the first e-mail.
I will deal shortly with the other bug reported here - regarding the
"parent" atribute of layers, which
is being retrieved as Layer, not LayerGroup.
I might add the "export" method to GIMP Image objects - but that is a
new feature , I am not sure if it should be backported to 2.8 .
-----Original Message----- From: Vladimir Rutsky Sent: Thursday, June 19, 2014 6:24 PM To: João Sebastião de Oliveira Bueno Cc: Ed . ; gimp-developer
to be added as well.Joao, Ed,
-- Vladimir Rutsky
Which functions in GIMP goes to PDB, and which stays only in libgimp?
As I understand, libgimp should contain _all_ functionality, that may be needed for external C plugins. So it's "low-level" library.
PDB functions are designed to be called from scripts for automation and easer writing custom plugins in Scheme/Python/Perl scripts. So there mostly should be "high-level" functions, since there is no point in calling "low-level" operations, like set_pixel(), due to performance overhead of PDB.
gimp_export_image() is "high-level" function: it does several operations on image as whole and optionally asks user for some input. If gimp_export_image() would be available though PDB, it could be called from any "fu"-script, that can call PDB functions, and there would be no need to export it specifically in Python, Perl, Ruby, C#...
Correct me if I'm wrong, since I'm new to PDB and GIMP development.
Best way to use C functions from Python is to write wrapper module in C
that will export methods as Python functions/classes (just as
GIMP-Python does).
Also you can load shared object and call C-function directly using
libffi library (presented as ctypes module in Python), but this
error-prone and really hackish way.
Subject: Re: [Gimp-developer] How to call gimp_export_image() from PythonpluginOn Wed, Jun 18, 2014 at 9:52 PM, Joao S. O. Bueno wrote:
-- Vladimir Rutsky
I will deal shortly with the other bug reported here - regarding the "parent" atribute of layers, which
is being retrieved as Layer, not LayerGroup. I might add the "export" method to GIMP Image objects - but that is a new feature , I am not sure if it should be backported to 2.8 .
I think this is a bug, that this function is not exported, but I agree with João about statement, that this function can be emulated so it's not worth risking stability of 2.8 release by exporting it.
-- Vladimir Rutsky
-- Vladimir Rutsky
My understanding is that libgimp is for C plugins. Many libgimp functions are in fact calls to PDB functions - see libgimp/gimppainttools_pdb.c for example. The distinction between "high" and "low" level is not the one used to determine what is in the PDB and what is not - despite what you say, there are gimp-drawable-set-pixel and gimp-drawable-get-pixel procs in the PDB.
It seems you are knowledgeable in writing interface code for Python. Why not add gimp_export_image to the available python functions?
Sent: Thursday, June 19, 2014 11:52 PM
To: Ed .
Cc: gimp-developer
Pythonplugin
GIMP-Python does).
Because it is not there.
One problem with the current implementation of Pygimp is exactly that it uses
C to wrap around calls do libgimp.
The problem with this approach is that one loses all the dynamic aspects from
Python for these objects:
The GIMP Python objects,as exposed in pygimp are "native" objects - as such
they can not be modified by pure Python code.
For writing Python plug-ins one does either use the objects ofered in Pygimp, with the functions enabled there in C code that requires a ton of boiler-plate for eachmethod made available, or use the Python PDB module, which allows one to call GIMP via the PDB.
So, if it is not clear yet, the "gimp_file_export" function just is
_not_ there.
It can be made available by a C patch in pygimp - but that is adding
functionality to a stable series.
Or it could be made available through the PDB - which would also make
it work from script-fu,
and whatever other bindings happen to work. That is also adding new
functionality.
The correct thing to do is to add it both ways - as an "export" method
for image objects,
and as a PDB call - in the 2.9 branch.
Now, talking about new features, you where the one experiencing with GIMP and GIO - that, on the contrary of this simple call, is something that matters: I'd very much like to rewrite GIMP Python using GIO - (so this kind of stuff would be a non issue in the future: everything available in C is ready without needing explicit wrappers with boiler plate code) - how far did you get with the GIO stuff?
-----Original Message----- From: Vladimir Rutsky Sent: Thursday, June 19, 2014 11:52 PM To: Ed .
Cc: gimp-developerSubject: Re: [Gimp-developer] How to call gimp_export_image() from Pythonplugin
Best way to use C functions from Python is to write wrapper module in C that will export methods as Python functions/classes (just as GIMP-Python does).
Also you can load shared object and call C-function directly using libffi library (presented as ctypes module in Python), but this error-prone and really hackish way._______________________________________________ gimp-developer-list mailing list
One problem with the current implementation of Pygimp is exactly that it uses C to wrap around calls do libgimp.
The problem with this approach is that one loses all the dynamic aspects from Python for these objects:
The GIMP Python objects,as exposed in pygimp are "native" objects - as such they can not be modified by pure Python code.For writing Python plug-ins one does either use the objects ofered in Pygimp, with the functions enabled there in C code that requires a ton of boiler-plate for eachmethod made available, or use the Python PDB module, which allows one to call GIMP via the PDB.
So, if it is not clear yet, the "gimp_file_export" function just is _not_ there.
It can be made available by a C patch in pygimp - but that is adding functionality to a stable series.
Or it could be made available through the PDB - which would also make it work from script-fu,
and whatever other bindings happen to work. That is also adding new functionality.The correct thing to do is to add it both ways - as an "export" method for image objects,
and as a PDB call - in the 2.9 branch.Now, talking about new features, you where the one experiencing with GIMP and GIO - that, on the contrary of this simple call, is something that matters: I'd very much like to rewrite GIMP Python using GIO - (so this kind of stuff would be a non issue in the future: everything available in C is ready without needing explicit wrappers with boiler plate code) - how far did you get with the GIO stuff?
What is GIO?
I heard about https://developer.gnome.org/gio/, but from it's
description I don't get how it can be related to GIMP and it's plugins?
-- Vladimir Rutsky
What is GIO?
It stands for "Gobject Introspection O"
It is a framework to,in a more or less automated form, expose C functions and gobject based classes to various languages - including Python.
The Python bindings for gtk+3.0 , ofr example, are GIO based - in this way, one does not have to re-especify every function or class one wants to expose to other languages in a manually written C (or other configuration) file.
Pygimp today has C modules which have to create Python objects that mimic
GIMP objects, and all manipulations of these objects are wrapped by
methods exposed
to Python which in turn call one of the libgimp functions.
With GIO, all libgimp functions could be called directly, and what we would need is an order of magnitude simpler implementation of the objects, directly in Python.
I am working on such a layer for GEGL, for example - http://github.com/jsbueno/python-gegl
PDB.It seems you are knowledgeable in writing interface code for Python. Why not
add gimp_export_image to the available python functions?Because it is not there.
with the functions enabled there in C code that requires a ton of boiler-plate for eachmethod made available, or use the Python PDB module, which allows one to call GIMP via the PDB.So, if it is not clear yet, the "gimp_file_export" function just is _not_ there.
What is GIO?
I heard about https://developer.gnome.org/gio/, but from it's description I don't get how it can be related to GIMP and it's plugins?-- Vladimir Rutsky
shouldn't also handle gimpexport (which is where gimp_export_image lives).Which functions in GIMP goes to PDB, and which stays only in libgimp?
GIMP UI - which pygimp already can initialise.Best way to use C functions from Python is to write wrapper module in C that will export methods as Python functions/classes (just as GIMP-Python does).
On 21.06.2014 00:59, Joao S. O. Bueno wrote:
What is GIO?
You're confusing GI[R] and GIO.
Regards, Michael GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD
"GIO is a file access library and part of GLib." - http://wiki.gimp.org/index.php/Hacking:Porting_file_plugins_to_GEGL_and_GIO#Porting_to_GIO
GIR is "(GObject Introspection Repository)" - http://blogs.gnome.org/johan/2008/06/01/introduction-to-gobject-introspection/
GIR is something that GIMP will fully support when someone gets around to it - currently I've volunteered to be that guy.
Ed
Sent: Friday, June 20, 2014 11:59 PM
To: Vladimir Rutsky
Pythonplugin
What is GIO?
and
methods exposed
js
So - that is "GIR", not "GIO".
How far had you got?
Ed
-----Original Message----- From: Joao S. O. Bueno Sent: Friday, June 20, 2014 11:59 PM To: Vladimir Rutsky
Cc: Ed . ; gimp-developerSubject: Re: [Gimp-developer] How to call gimp_export_image() from Pythonplugin
What is GIO?
gobject based classes to various languages - including Python.The Python bindings for gtk+3.0 , ofr example, are GIO based - in this way, one does not have to re-especify every function or class one wants to expose to other languages in a manually written C (or other configuration) file.
Pygimp today has C modules which have to create Python objects that mimic GIMP objects, and all manipulations of these objects are wrapped by methods exposed
to Python which in turn call one of the libgimp functions.With GIO, all libgimp functions could be called directly, and what we would need is an order of magnitude simpler implementation of the objects, directly in Python.
js
My progress so far as been to read a little about GIR.
Sent: Sunday, June 22, 2014 3:43 PM
To: Ed .
Pythonplugin
Ed
What is GIO?
js
